vpp redownload call timed out <mdmclienterror:72>
  • February 18, 2019
  • 407 replies
  • 1254 views
I am seeing a lot of our systems having the "vpp redownload call timed out <mdmclienterror:72>" error when cliets try to install VPP apps via Self Service on MacOS (most clients are 10.14.2).
I have tried clearing the failed commands, reconning, re-enrolling etc with no luck.
I am hesitant to revoke all apps as I have seen suggested because I am concerned about the number of people who will experience iTunes notifications about apps not being assigned (the staff at this school are fragile...).
Any advice would be appreciated.
Best answer by pbowden
@mjames @whitebeer The issue with storedownloadd crashing during MAS installs is fixed in 10.14.4 Beta 4 (18E205e). This is RADAR 47685116. Let me know if you still see problems after the update. For clarity, typical symptoms of this bug:
- Larger MAS apps like Xcode and Office fail to install and leave behind an .appdownload stub
- Needing to run multiple jamf recon commands to coerce apps to install
- MDMClientError:72 failed command seen in JSS
I've updated https://macadmins.software/mas with the latest info. The largest outstanding issue that I'm still tracking is the inability to update MAS apps through MDM when the user has the app perpetually open.
whitebeer
  • February 18, 2019
Hi @mjames ,
I've got the exact same problem with the VPP apps - especially with larger apps like XCode and Microsoft Office. For me a 'recon' pushed the download a step further but only some apps ended on the client, the others were still downloadstubs 🙄 I've tested with our corporate network (proxy+firewall in place), our hotspot (only firewall) and my private WLAN - but none of them was working. Most of our Macs are 10.14.3.
  • February 18, 2019
@whitebeer it is much the same for us - larger apps like Xcode, Fusion 360 etc - and most of our macs are 10.14.2...
  • February 18, 2019
@mjames @whitebeer check your crash logs (Console > System Reports) and see if storedownloadd is crashing during app install. See https://macadmins.software/mas for more info and the RADAR that’s tracking this issue.
  • February 18, 2019
Ive seen this as well. The issue we saw was is apple changed the app store communication protocol and we have to upgrade our proxy to resolve. once systems went outside of the proxy network the VPP apps worked as designed.
  • February 19, 2019
@pbowden
Thanks for the tip - we are seeing errors in the download in the console - but not the same one in the link
default 09:10:30.379644 +0800 storedownloadd sending status (Xcode): 76.559287% (835.138401)
default 09:10:31.964963 +0800 storedownloadd sending status (Xcode): 76.928800% (833.639385)
default 09:10:33.558941 +0800 storedownloadd sending status (Xcode): 77.360559% (831.393047)
default 09:10:35.159762 +0800 storedownloadd sending status (Xcode): 77.795357% (828.850088)
default 09:10:36.753070 +0800 storedownloadd sending status (Xcode): 78.261495% (826.747507)
default 09:10:38.343536 +0800 storedownloadd sending status (Xcode): 78.714579% (824.785034)
default 09:10:39.944908 +0800 storedownloadd sending status (Xcode): 79.147202% (822.968359)
default 09:10:41.527408 +0800 storedownloadd sending status (Xcode): 79.578090% (821.198435)
default 09:10:43.127732 +0800 storedownloadd sending status (Xcode): 79.999822% (819.534362)
default 09:10:44.727223 +0800 storedownloadd sending status (Xcode): 80.447251% (817.769275)
default 09:10:45.518932 +0800 storedownloadd Task <A6246E20-48A1-4666-AD63-1F483C9C76CD>.<0> response ended
default 09:10:45.519214 +0800 storedownloadd Task <A6246E20-48A1-4666-AD63-1F483C9C76CD>.<0> done using Connection 1
default 09:10:45.625997 +0800 powerd Process storedownloadd.18112 Released PreventUserIdleSystemSleep "URLConnection in progress" age:00:05:50 id:4295009410 [System: PrevIdle DeclUser kDisp]
default 09:10:45.626675 +0800 storedownloadd sending status (Xcode): 80.645162% (817.000000)
default 09:10:45.628294 +0800 storedownloadd sending status (Xcode): 80.645162% (817.000000)
error 09:10:45.634849 +0800 storedownloadd NSURLConnection finished with error - code -1100
error 09:10:46.773129 +0800 storedownloadd NSURLConnection finished with error - code -1100
default 09:10:46.838382 +0800 storedownloadd setPrimaryAppPath "(null)" forProductIdentifier "com.apple.dt.Xcode"
default 09:10:47.170217 +0800 kernel process storedownloadd[18112] crossed memory high watermark (30 MB); EXC_RESOURCE supressed due to audio playback.
default 09:10:47.170233 +0800 kernel EXC_RESOURCE -> storedownloadd[18112] exceeded mem limit: ActiveSoft 30 MB (non-fatal)
I've done a little looking about but haven't found anything much about "NSURLConnection finished with error - code -1100" - it looks like it is related to App Transport Security - I am wondering if it has anything to do with our network filtering/monitoring software now.
EDIT
After a few minutes - the logs reported this.
default 09:13:35.775064 +0800 storedownloadd estimatedTimeRemaining 1408.4295
default 09:13:35.775224 +0800 storedownloadd sending status (Xcode): 81.290323% (1411.429500)
default 09:13:36.273213 +0800 storedownloadd installClient:currentState:package:progress 4.979308682338265:timeRemaining 1408.4295:state 3
default 09:13:36.273383 +0800 storedownloadd estimatedTimeRemaining 1408.4295
default 09:13:36.273592 +0800 storedownloadd sending status (Xcode): 81.290323% (1411.429500)
default 09:13:36.285357 +0800 com.apple.CommerceKit.TransactionService ISServiceProxy: Connection to com.apple.storedownloadd.daemon was interrupted - removing connection from pool
default 09:13:36.286628 +0800 com.apple.CommerceKit.TransactionService ISServiceProxy: Error from com.apple.storedownloadd.daemon - Error Domain=NSCocoaErrorDomain Code=4097 "connection to service named com.apple.storedownloadd.daemon" UserInfo={NSDebugDescription=connection to service named com.apple.storedownloadd.daemon}
default 09:13:36.300127 +0800 loginwindow -[PersistentAppsSupport applicationQuit:] | for app:storedownloadd, _appTrackingState = 2
default 09:13:59.927878 +0800 ReportCrash Saved crash report for storedownloadd[18112] version 1.0 (1) to storedownloadd_2019-02-19-091359_SCT16324.crash
  • February 19, 2019
@mjames good info. That very last line indicates that storedownloadd crashed. Take a look at the crash report in Console > System Reports to see if it’s the same as what I reported.
  • February 19, 2019
@pbowden
It does indeed
Process: storedownloadd [75894]
Path: /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Resources/storedownloadd
Identifier: storedownloadd
Version: 1.0 (1)
Code Type: X86-64 (Native)
Parent Process: launchd [1]
Responsible: storedownloadd [75894]
User ID: 0
Date/Time: 2019-02-15 08:47:44.245 +0800
OS Version: Mac OS X 10.14.3 (18D109)
Report Version: 12
Anonymous UUID: 828A396E-DB42-F5FF-7B0C-676921102424
Sleep/Wake UUID: A5383D56-FAA5-487F-AB70-8105C9E23B5E
Time Awake Since Boot: 300000 seconds
Time Since Wake: 170000 seconds
System Integrity Protection: enabled
Crashed Thread: 6
Exception Type: EXC_BAD_INSTRUCTION (SIGILL)
Exception Codes: 0x0000000000000001, 0x0000000000000000
Exception Note: EXC_CORPSE_NOTIFY
Termination Signal: Illegal instruction: 4
Termination Reason: Namespace SIGNAL, Code 0x4
Terminating Process: exc handler [75894]
Application Specific Information:
dyld3 mode
API MISUSE: Resurrection of an object
  • February 19, 2019
@mjames at least you’re hitting the well-known bug that Apple is looking at.
donmontalvo
Forum|alt.badge.img+36
  • February 20, 2019
@pbowden any chance we can get the ticket number so we can open a similar ticket with AppleCare Enterprise Support?
  • February 20, 2019
@donmontalvo take a look at https://macadmins.software/mas as it lists the RADAR bug numbers
donmontalvo
  • February 21, 2019
Awesome good to go thanks!
  • March 5, 2019
  • March 7, 2019
Thanks @pbowden - that is what I was hoping for.
donmontalvo
  • March 7, 2019
@pbowden wow, didn't notice, but yea, test computer hasn't had any issues yet downloading VPP stuff. #knocksOnParticleBoardDesk
  • April 15, 2019
EDIT: It looks like it's because I'm trying to download an app that's had a newer version released as a separate app, no longer offering the older one. Confirmed I cannot download the older version on any computer, so it seems like this is the true issue.
I'm still seeing this issue on one of our computers. It's fully updated (currently 10.14.4). It doesn't seem like it's everyone, though it could be this one app. All in all, wanted to add to the conversation that I'm still seeing this issue.
My next thought is to change the download parameters, and make it download automatically to see if the issue persists.
Cayde-6
Forum|alt.badge.img+22
  • June 10, 2019
@pbowden
We are still seeing this issue on 10.14.5, is there anything else to look into?
  • July 25, 2019
Yea seeing a very similar issue now also displaying on 10.14.6 Trying to get VPP Slack to deploy automatically to selected smart groups.
Install App - Slack VPP redownload call timed out <MDMClientError:72>
any more updates on this would love to hear them :)
  • July 25, 2019
i got this error yesterday and today on some machines. 10.14.5 and 10.14.6
  • July 25, 2019
We are also seeing this issue on most machines as they enroll from 10.14.4-10.14.6. Hoping to find a solution.
  • July 25, 2019
I'm also seeing this on 14.4-14.6. What I've found is if I go under the management tab on the device in question, cancel the failed command and then send a blank push, it seems to start the download. I know its far from ideal, but if you need it done, this seems to be working for me.
  • July 29, 2019
@jbosma - Yeah we do this already and it works only once we recon again on the device. I hate this workaround since we are a DEP house and most computers are setup at random times, in different time zones, by users who can't flush it all out of Jamf.
No idea where to even start. We are reopening our Apple ticket, since obviously this was not resolved with the 10.14.4 update.
  • July 29, 2019
If within your computer provisioning a script is used, you can use the jamf api to clear the failed commands and then run a Jamf recon. This article was helpful for me (https://aporlebeke.wordpress.com/2019/01/04/auto-clearing-failed-mdm-commands-for-macos-in-jamf-pro/).
  • July 31, 2019
Hi all, just opened a case about this. Seeing this one both High Sierra and Mojave, where roughly half the environment recieves the updated app and the other half gets the VPP redownload call timed out error (visible from the Computer Record). Any resolutions to this yet?
Cayde-6
  • July 31, 2019
Case with Apple or Jamf?
  • August 1, 2019
OS 10.14.6 Happening on Multiple computers that were just enrolled and reconned. What a waste of time redoing something that should be working.
