Webex Call Setting
  • October 20, 2023
  • 51 views
Is there a way to force the setting in Webex to automatically use webex for the "start call with" setting with a script or policy? There are some users that have this set to Facetime. In Webex, the 3 options available are Webex, Facetime and Microsoft Teams.
I've found this plist that may have some power to change:
/Users/(CurrentUser)/Library/Preferences/com.apple.LaunchServices/com.apple.launchservices.secure.plist
I'm unsure how to change these variables. I tried using the defaults command but no luck.
Thanks in advanced!
AJPinto
  • October 23, 2023
You will need to reach out to Cisco. WebEx on macOS is a very poorly made product. In a well-made product you would manage this with a Configuration profile. However, Cisco has specifically designed WebEx to not respect /Library/Managed Preferences. I went round and round on managing WebEx on MacOS with Cisco maybe 6 months back, a total waste of time.
In the off chance my past experiences can help: Webex stores its preferences in /Library/Preferences/com.cisco.webexmeetings.config.plist. I am not sure what key you will need to modify, but if it can be set it will be set here. I currently just deploy the .plist with a package rather than creating it with a script. Because it's not a Configuration Profile, users can change the settings. So, I wrote an EA to monitor the setting we want to set and rerun the package if they are ever changed.
Plist:
<?xml version="1.0" encoding="UTF-8"?> <!DOCTYPE plist PUBLIC "-//Apple//DTD PLIST 1.0//EN" "http://www.apple.com/DTDs/PropertyList-1.0.dtd"> <plist version="1.0"> <dict> <key>OrganizationID</key> <string>String here</string> </dict> </plist>
Extension Attribute:
#!/bin/sh if [[ -f /Library/Preferences/com.cisco.webexmeetings.config.plist ]]; then vers=$(/usr/bin/defaults read /Library/Preferences/com.cisco.webexmeetings.config.plist OrganizationID) echo "<result>$vers</result>" else echo "<result>Not Configured</result>" fi
  • October 25, 2023
If you need to do this programmatically you should probably look into duti, a command line tool for setting URL schemes and UTI associations in macOS. It has not be updated for many years, however, so I don't know how well it works at this point.
