What non-standard port works well for JSS if we choose to use 8443 for iCal Server?
b_mike
New Contributor III
I have a client that finished their Jumpstart this week. We are very likely to have the JSS be on a server that shares iCal server and port 8443 will be in conflict in this case.
https://jamfnation.jamfsoftware.com/article.html?id=120
Has anyone documented a good alternate port to run tomcat? I've done some light searching but haven't seen this documented. If no one has a good guide, I'll check to see what ports our firewalls allow (or if there is consensus on which ports are generally open on most firewalls) and document our decision here with an answer when we decide what we will do with tomcat on the JSS that sits in a DMZ / publicly routable IP address.
1 ACCEPTED SOLUTION
Josh_S
Contributor III
You can go through the trouble of changing the port (to anything really, but the standard https port 443 jumps to mind), but you'll have to modify the configuration files with every release. It's easier to have a dedicate machine, or VM, for your JSS/mySQL database.
Personally, I think you should take a step back and really think about whether you want this installed on Apple hardware. Xserves are out, unless you like getting replacement parts from eBay. Mini's really aren't true servers unless you're a very small shop. And, unless your server room guys are very lenient, they will not be happy with a MacPro in the server room.
I think, in the long run, you'll be happier with some flavor of Linux (or Windows if you're a Windows shop) running your JSS and then leveraging whatever network filer you currently have in place for the distribution point(s). It's easier to do in the beginning rather than later on. It also has the benefit, in most enterprise environments, of shifting the server maintenance pieces of managing a JSS to a group of people that manage a bunch of other servers. This lets you, or whoever will be doing it, focus on managing the Macs.
Also, have the clients point at a DNS CNAME. Your server will (eventually) die, it's easier to change a DNS record to point at a new server then to tell all the clients to point at a new server.
My 2Β’
3 REPLIES 3
Josh_S
Contributor III
My 2Β’
b_mike
New Contributor III
Josh - your points are perfect. I especially appreciate the warning that each release will change the ports.
For us, the updating of the software is an unknown since we're starting with things, but Mac mini are more than enough horsepower to run things and the cost to add Windows / Linux to the technology stack is likely going to be higher than the cost to document and have a configuration step each release.
We do overload DNS in the sense that each function has it's own entry: mail, chat, jss, od, web, www, wiki, dns, dhcp
This points at one host currently, but can clearly move to different servers if/when we want to change things. If people like, I'll probably make a short slide of the small config we chose in case it helps places that are smaller shops and don't want / don't need full time IT staff to manage things. The enterprise approach would clearly be to run things on it's own VM or server as the scaling and site preference is on the pendulum of "host all loads on metal" vs "virtualize all the servers" at the time you make a JSS decision.
For now, we'll run JSS on port 9443 and let iCal server have 8443 on our Mini that's hosting everything. We're not likely to ever need WebSphere and Apple doesn't claim to ever use 9443.
dmw3
Contributor III
One solution for Apple servers we have looked at is this:
http://www.precursor.ca/rais/#Results
It allows multiple MacMinis to be housed in a rack unit. have a look at the Resources section of the page.
