why Managed Preferences not taking effect
  • August 28, 2014
  • 0 replies
  • 7 views
None of my managed preferences are working except one. I have set up following Managed Preferences.
  1. Disable Blue Tooth
  2. Disable iTunes
  3. Dock Item (Adding an app VLC)
  4. Home Sync Settings to Sync the folders.
  5. Show Home Sync Status in Menu Bar
Only No. 5 worked thats too after multiple restart and logging in from the same user.
I have set most of them at "User-Level at every login".
I think I better move to Configuration Profiles --> Mobility it was working fine for me but can someone guide me if Managed Preferences doesn't work at all.
I am testing AD accounts here.
