WiFi Issues
  • March 23, 2017
  • 8 views
Hello, I'm using a connection 802.1X in my network config, but, the issue that I'm getting is that sometimes and randomly, after some computers wake up, the WiFi doesn't connect, it only shows the WiFi icon trying to connect, also, when I checked the System Preferences>>Network>>Advanced, I notice something odd, in the WINS tab, in the Workgroup field, it says WORKGROUP instead of the Domain Name that usually appears in it, also, in the DNS tab, all DNS disappears with the information of the domain, until now, the only solution that works is doing a log out and login again, Any advices?
1 reply
  • April 19, 2017
Hope this works for someone else, when I checked the unicast lim, the value was set on 3, I change it to 0 and works fine again, I'll let the command, hope you find it useful:
sudo sysctl -w net.link.ether.inet.arp_unicast_lim=0
