My organization is looking to move our iPads we have distributed through out to a central SSID and getting rid of the current one they are connected to. I have created the new config profile and can push it to my test device and remove the old wifi config but to connect it to the new SSID, you have to go through setting, select the new one, and then accept the cert for it. My question is, is there a way to switch it over with out the end user having to accept it or is that just the nature of the beast?
Wifi Switch for iOS
