Wireless SSID Help
  • May 16, 2011
  • 5 views
So i know this has been asked before but it was a couple of years ago. At my school we have 1 SSID for the entire district GISD Wireless. My problem is i can tell it to connect to the ssid at first boot but when you restart it does not remember the password because its not in the keychain. I have even tried to connect to the network in my base image but when you restore the image it will not connect until you log in and click on the network. I read there is some kind of package that will connect and insert in the keychain but i cant find it.
Thanks,
Brian Weeks
Brian Weeks Systems Engineer
Groesbeck ISD
1202 N. Ellis
Groesbeck, TX
Office: (254) 729-4130
Email: bweeks at groesbeckisd.net
Website: http://www.groesbeckisd.net
1 reply
  • May 16, 2011
The easiest way is to move the keychain entry from the user's login keychain to the System keychain. You can use /Applications/Utilities/Keychain Access to do it; just drag and drop. That should do it, I think.
