Yosemite Automatic Home Drive Mount
  • December 2, 2014
  • 46 replies
  • 191 views
Hi there,
We are currently testing 10.10 and are experiencing the following problem.
Our macs are bound to AD and when they log in the UNC path from AD is used to mount the home folder. This worked fine in 10.8/10.9.
For some reason, the home folder is now not mounting at all in 10.10. All I am seeing is a question mark on the dock which would indicate a nil alias but it seems like the share is not mounting at all as I am not seeing anything in /Volumes/ . Is anyone else having similar problems with yosemite and the AD plugin?
  • December 2, 2014
I'm seeing this as well. Can you mount via the finder? I was at least able to do that without entering my credentials.
  • December 2, 2014
Yea it works perfectly via the finder and doesn't request credentials. Need to resolve the issue with it not auto mounting however. Not seeing any useful logs on why its failing !
  • December 2, 2014
We have noticed this on our 10.10 test machines as well, but sometimes it will mount. It seems to be hit or miss. When it doesn't mount, usually logging off and back on again resolves the issue.
I have always had issues with AD home drives mounting reliably with OS X. Using a Connect to Server entry seems to work every time.
  • December 2, 2014
Strange how this functionality is almost always broken when a new Mac OS drops...
davidacland
  • December 2, 2014
This is one of the reasons we disable that option and use a login script instead. It mounts every time this way.
just finished a 10.10.1 deployment with a login script and all is well.
  • December 2, 2014
Like @davidacland, we disabled that function in the AD plug-in long ago and use a custom app/script called at login by a LaunchAgent and have no issues with mounts. In addition to working more reliably. it also helped us get around problems for some users where the network wasn't available and the plug-in was not timing out in an appropriate amount of time, so they were getting a very long login delay while the Apple AD plug-in kept attempting to mount their share. The script in the app checks to see if it can connect to our network first, and only if successful tries to mount their home share, or just exits. Having it as a double clickable app in the Applications folder means users can just double click it if they connect to the network later and it mounts their home drive.
  • December 3, 2014
thanks for the idea davidacland and mm2270. i put this together this morning. the only issue I'm having is using dockutil to add the drive in the dock - works perfectly when launching the script locally however, running it as a launch agent doesn't seem to work. this may be useful for some one
#Script to check if we have a network connection and then mount users home drive
#This will be delivered by launch agent
#Author: James Durler
#Date: 3/12/2014
logFile="/var/log/UAL/homedrive.log"
touch $logFile
function mountDrive {
#Using $USER to determine the user running this command to be used in the dscl command to find users SMB Home Path smbhome=dscl '/Active Directory/ARTSLOCAL/All Domains' -read /Users/$USER SMBHome | awk '{print $2}' | sed -e 's/\\\\/smb:///g' | sed 's:\\:/:g' echo "Untrimmed SMB Home Path is $smbhome" >> $logFile #trim the variable smbhome, so we can test if the file share we are trying to mount to is available #first we are removing the smb:// - this should always be the start of the users smbhome path newsmbhome=$(echo $smbhome | cut -c 7-) echo "Removed the smb:// variable is now $newsmbhome" >> $logFile #now remove everything after the first /, so delimitting by the / after INF-FS06 newersmbhome=$(echo $newsmbhome | cut -f1 -d"/") echo "Removed everything after the first slash, we now have the file share to ping for availability $newersmbhome" >> $logFile
#now pinging the file share to see if it is available if ping -c 1 $newersmbhome &> /dev/null;then #file share is available echo "Mounting Home Drive" >> $logFile mkdir /Volumes/Home Drive mount -t smbfs $smbhome /Volumes/Home Drive/ echo "adding dock item" >> $logFile /Users/Shared/dockutil.py --add /Volumes/Home Drive/ --view grid --display folder /Users/$USER else #file share is unavailable echo "File share is not responding" fi
#Check if the home drive is already mounted before doing anything else
if [ -d /Volumes/Home Drive ]
then
echo "Home Drive already Mounted, exiting Script"
if ping -c 1 inf-dc01 &> /dev/null;then
#inf-dc01 is responsive, get users SMB home path echo "inf-dc01 is responsive, getting users SMB home path" mountDrive
elif ping -c 1 inf-dc02 &> /dev/null;then #inf-dc02 is responsive, get users SMB home path echo "inf-dc02 is responsive, getting users SMB home path" mountDrive
elif ping -c 1 inf-dc03 &> /dev/null;then #inf-dc03 is responsive, get users SMB home path echo "inf-dc03 is responsive, getting users SMB home path" mountDrive
elif ping -c 1 inf-dc04 &> /dev/null;then #inf-dc04 is responsive, get users SMB home path echo "inf-dc04 is responsive, getting users SMB home path" mountDrive
else echo "No Domain Controller is responding, do nothing" fi
davidacland
  • December 3, 2014
In case it helps, I have been using mount -t smbfs for years, always had mixed results with folders being left behind, drives not mounting etc.
I've started using osascript a bit more recently which for your script would look like this:
# Mount the network home
    mount_script=`/usr/bin/osascript > /dev/null << EOT
    tell application "Finder"
    activate
    mount volume "smb://${smbhome}"
    end tell
EOT`
It handles creating the mount point and can switch between kerberos and username/pasword very nicely.
(the EOT bit at the end can't have any whitespace before it in case anyone wondered!).
  • December 4, 2014
Hey David,
Thanks for that. My major problem right now is that dockutil for some reason isn't working properly when used with a launch agent.
a user launch agent executes this script - running the script manually works perfectly and populates the dock.
Has anyone had similar issues with dockutil and launch agents? I can see it is trying to add the dock item as the dock is killed and refreshed but no icon is added.
davidacland
  • December 4, 2014
Not sure about other people but I have always had this behaviour from dockutil. Sometimes it will work fine, other times it will fail. I've had more success using it to write into the user template folder so its not trying to do too much at login.
Its probably not dockutil's fault, the Dock is a surprisingly difficult thing to manage. I've had inconsistent results using Workgroup manager in the "olden" days and config profiles more recently. Preference caching in the recent OSes are making it even harder! Just to rule that out, try adding "killall cfprefsd" at the start of the dock util script.
russeller
  • December 10, 2014
Looks like they've made some changes in 10.10 with LaunchAgents. See here: http://stackoverflow.com/questions/26761552/osx-yosemite-loginwindow-agent-not-persisting-into-login it says:
I have heard that 10.10 has a complete rewrite of launchd, and that it no longer executes multiple launchd processes for each user but only has one and uses xpc (cross process communication).
I haven't done much more research but I was using a LaunchAgent with ```
LimitLoadToSessionType = Aqua;
and it is not launching in 10.10.1 when a user logs in to mount their homefolder. I'm looking at permissions, etc. I might have to change how it launches at login if I can't find a way to use a LaunchAgents in 10.10. Has anyone else figured this out already?
russeller
  • December 10, 2014
This guy kept accidentally calling a Launch Agent a "Lunch Agent", seems like a better name.
https://discussions.apple.com/thread/6622442?start=0&tstart=0
russeller
  • December 10, 2014
Yep- It was a permission problem for me. Works now.
RobertHammen
Forum|alt.badge.img+29
  • December 17, 2014
@jamesdurler, I'm trying something similar (on Mavericks) with a launchd (to run the mountdrive script as the user), and while the SMBHome is mounted, dockutil doesn't add it to the Dock correctly (it adds the folder icon, but clicking on the it just reveals an empty folder). If I remove that folder from the dock, dismount the SMBHome, and then re-run the script manually, it works. Is this what you are seeing?
  • December 18, 2014
Does a Launch Agent occur after pre-boot on an encrypted disk? If it does then it might solve a problem with encrypted disks.
Looking for a way around the issue of FileVault/Yosemite/AD UNC mapped home folder on a non-networked computer.
RobertHammen
  • December 18, 2014
Yes. LaunchAgents run as the user, after the user logs in. Which of course happens after the FV2 preboot.
  • March 29, 2015
Do you guys mind sharing your login scripts and user launch agents? Having this same issue. Thank you!
  • May 5, 2015
Having the same issue. Our network home folder won't mount. It appears as a question mark on the dock.
Yosemite 10.10.3
JSS 9.72
davidacland
  • May 5, 2015
@esantiago are you using the AD plugin in directory utility to mount the SMBHome? If you are, a ? in the Dock is quite common for first login. I would suggest mounting the network home via a script instead.
GitHub link to our script is in this thread: https://jamfnation.jamfsoftware.com/discussion.html?id=14283
  • May 5, 2015
@davidacland
Hey,
I am using the directory utility to mount the SMB home. Do I need to turn that feature off in directory utility for that script to work. I set that script as a log on script through policy in JSS. However It's still not mounting. I checked the logs of the policy and it shows it retrieving the SMBHOME attribute for esantiago ....
Thanks for your help
davidacland
  • May 5, 2015
Correct, you would use one or the other.
I would suggest testing it manually first when logged in as an AD user. If you are using in a Casper policy you might want to switch $USER for $3 as the policies will run as root otherwise.
  • May 5, 2015
So I am on 10.10.3 and I see that the user's home directory mounts, but it has the wrong permissions, which is why the user cannot access it. Any idea how to get this fixed?
I know some of you have suggested using scripts, but will those work when a user connects to the machine via ssh?
ae204212:~ root# grep nethome /etc/auto_master /nethome auto_nethome -nobrowse,hidefromfinder
ae204212:~ root# cat /etc/auto_nethome * -fstype=smbfs ://ae.nas.gatech.edu/&
ae204212:~ root# mount | grep dijuremo
//dijuremo@ae.nas.gatech.edu/dijuremo on /nethome/dijuremo (smbfs, nodev, nosuid, automounted, nobrowse)
ae204212:~ root# ls -ld /nethome/dijuremo
drwx------+ 1 root ADDomain Users 16384 Apr 29 18:21 /nethome/dijuremo
So I had tried to log in the machine as "dijuremo" and as you can see, the file system is mounted, but, the mount point is owned by root, so the user cannot write to it and this is messing up things.
davidacland
  • May 5, 2015
If I'm using mkdir to create the mount point and mount_smb, I would have the user do both of the tasks so there isn't a permissions issue.
  • May 5, 2015
Furthermore, I have discovered that mounts seem to work for "admin" users, but not regular users. I have two accounts, my account ae-dijuremo (which is an admin in the OS X machine) seems to be able to get the home directory mounted properly. However, dijuremo, a regular user, cannot.
ae204212:~ root# ls -ld /nethome/*
drwx------ 1 ae-dijuremo wheel 16384 May 5 15:19 /nethome/ae-dijuremo
drwx------
FAIL for dijuremo
ae204212:log root# ssh dijuremo@localhost
Password:
Last login: Tue May 5 14:54:29 2015
Could not chdir to home directory /nethome/dijuremo: Permission denied
-bash: /nethome/dijuremo/.bash_profile: Permission denied
Success for ae-dijuremo
ae204212:log root# ssh ae-dijuremo@localhost
Password:
ae204212:~ ae-dijuremo$ pwd
  • May 5, 2015
@davidacland I am using automount in this case, which automatically should create the folders, so I think the issue is somehow with this daemon on the new OS X 10.10.X.
In our AD, all users have their attributes set, inluding home directories, so auto mount should try to mount the homes in /nethome/$username
