My Environment:
NetSuS with a 10.9.5 boot image
Casper 9.6.2
SMB DP
Image:
10.10.1 AutoDMG created dmg with updates applied, pretty basic
A user creation package
Hardware:
Macbook Pro 2013, not encrypted. Had a previous Casper image of 10.9.5.
Issue:
When I apply the configuration that only has the AutoDMG created dmg file, it block copies, installs, reboots but comes up to a grey screen with a Circle and Line through it. I've come across this before, but only when i've had PRAM issues or laid an image down to hardware that doesn't support it. Resetting the PRAM temporarily removes the circle and replaces it with an Apple but it comes back.
Questions:
Do I need to boot to 10.10 to image 10.10?
Has anyone run into this?
How are you imaging your 10.10 machines?
Thanks in advance!
