Hi:
Working with 10.10.1 and 10.10.2, Casper 9.63. From Terminal, locally on a machine, I'm running sudo jamf setComputerName -name "Name". Then I'll run sudo jamf recon. Just after, in Terminal (via scutil --get HostName/LocalHostName/ComputerName) and in System Prefs "Sharing" the new name is good. As soon as I reboot the machine, the old name comes back. Why won't the name change stick? Has anyone seen this or have a fix for it? Thanks
*Edit: I now realize I should've posted initially that the machine was imaged via Target Disk Mode and Casper Imaging 8.63 before it was migrated to our 9.63 JSS. This may or may not be part of the issue, still to be determined.
