Blog
From ClickOps to Code: Terraforming a Live System
  • Apr 16, 2026 6:48 PM UTC
  • 659 views
mscottblake
There are hundreds if not thousands of Terraform examples and walk throughs on the internet today. Most of them start in a clean environment. They assume a brand new account. No history. No surprises.
But that’s rarely the situation most of us inherit.
More often, we’re working on something that’s been evolving for years:
  • Resources created manually in a GUI
  • Naming conventions that shifted over time
  • Temporary fixes that became permanent
  • Configurations that “just work,” but nobody is entirely sure why
Applying Infrastructure as Code (IaC) using Terraform in an existing, already-provisioned environment is often called Brownfield Terraform.
You’re not building from scratch.
You’re (very carefully) translating the current reality into code.
What Does Success Actually Look Like?
Before getting into mechanics, it helps to define the goal. In a brownfield migration, success is not:
  • Rebuilding everything
  • Refactoring immediately
  • “Cleaning it up” on day one
Success is simpler. You run:
terraform plan
And Terraform responds with:
No changes. Your infrastructure matches the configuration.
That’s the first milestone.
At that moment:
  • Terraform understands your system
  • Your state matches production
  • Future changes can flow through code
Everything else builds from there.
Step 0: Decide Where State Lives
Before importing anything, answer one question:
Where will Terraform state live long-term?
If this system matters, you probably don’t want local state files. A remote backend with locking enabled sets the tone early.
Example:
terraform {
  required_version = ">= 1.5.0"
  backend "s3" {
    bucket  = "terraform-state"
    key     = "live-system/terraform.tfstate"
    region  = "us-east-1"
    encrypt = true
Then:
terraform init
It’s a small step, but it changes the way the project feels. It becomes intentional.
Step 1: Configure the Provider
For this post, I’ll use Okta as an example provider because it’s a system I’m familiar with, but the concepts apply to many others.
A minimal provider setup might look like:
provider "okta" {
  org_name  = "example"
  base_url  = "okta.com"
  api_token = var.okta_api_token
variable "okta_api_token" {
  type      = string
  sensitive = true
Then:
export TF_VAR_okta_api_token="****"
terraform init
At this point, Terraform can talk to the API, but it doesn’t know anything about what already exists.
Step 2: Discover What Exists (This Is the Real Work)
Before Terraform can manage something, it needs to know it exists.In a greenfield project, that’s trivial because you’re defining everything. In a brownfield system, discovery is often the most time-consuming step. Some Terraform providers support advanced “list” or query-style features that can generate configuration automatically.Okta does not. At least not yet.So how do you move from “resources exist somewhere” to usable Terraform import blocks?
You have two practical approaches:
  1. Manual discovery (reasonable for small systems)
  2. Scripted discovery (necessary for large systems)
Let’s walk through both.
Option 1: Manual Discovery (Small Environments)
If you’re working with:
  • A handful of resources
  • A limited number of types
  • A system you can comfortably review in the UI
You can query the API manually.
For example, listing groups:
curl -s \
  -H "Authorization: SSWS ${OKTA_TOKEN}" \
  -H "Accept: application/json" \
  "https://example.okta.com/api/v1/groups"
This returns JSON listing each group. The output will include something similar to this, but likely with more data included:
    "id": "00g1abcdXYZ12345",
    "profile": {
      "name": "Engineering"
    "id": "00g2efghABC67890",
    "profile": {
      "name": "Finance"
From here, you could manually write import blocks:
import {
  id = "00g1abcdXYZ12345"
  to = okta_group.engineering
import {
  id = "00g2efghABC67890"
  to = okta_group.finance
For very small environments, this is perfectly reasonable.
But it doesn’t scale.
The Scaling Problem
In a mature system, you might have:
  • Hundreds or thousands of resources
  • Multiple resource types
  • Deep relationships between objects
At that point:
  • Manual copy/paste becomes error-prone
  • Naming conventions drift
  • You will miss something
This is where scripting stops being optional.
Option 2: Scripted Discovery (Large Environments)
The pattern is consistent across systems:
  1. Query the API
  2. Extract stable identifiers
  3. Output deterministic Terraform import blocks
  4. Repeat by resource type
#!/usr/bin/env python3
Generate Terraform import statements for Okta groups.
This script:
1. Fetches all groups from Okta API
2. Generates import blocks with resource names based on group names
3. Handles pagination automatically
4. Respects Okta API rate limits
Usage:
    export OKTA_API_TOKEN=your_token_here
    python3 generate_group_imports.py
Output:
    - terraform/imports.tf: Import statements
import os
import re
import sys
import time
import requests
# Okta API configuration from environment variables
OKTA_ORG_NAME = os.getenv("OKTA_ORG_NAME", "example")
OKTA_BASE_URL = os.getenv("OKTA_BASE_URL", "okta.com")
OKTA_API_TOKEN = os.getenv("OKTA_API_TOKEN")
OKTA_URL = f"https://{OKTA_ORG_NAME}.{OKTA_BASE_URL}"
# Output file
IMPORT_FILE = "terraform/imports.tf"
def _slugify(text: str) -> str:
    Convert a group name to a valid Terraform resource identifier.
    Example: "Admin - Read Only" -> "admin_read_only"
    # Remove special characters and replace spaces/hyphens with underscores
    slug = re.sub(r"[^\w\s-]", "", text)
    slug = re.sub(r"[\s-]+", "_", slug).lower().strip("_")
    return slug
def _get_okta_headers() -> dict[str, str]:
    """Return headers for Okta API authentication."""
    if not OKTA_API_TOKEN:
        print("Error: OKTA_API_TOKEN environment variable not set", file=sys.stderr)
        print("\nSet it with: export OKTA_API_TOKEN=your_token_here", file=sys.stderr)
        sys.exit(1)
    return {
        "Authorization": f"SSWS {OKTA_API_TOKEN}",
        "Accept": "application/json",
        "Content-Type": "application/json",
def _fetch_all_groups() -> list[dict[str, str]]:
    Fetch all groups from Okta API with pagination.
    Returns:
        list: List of group dictionaries with 'id' and 'name'
    print("Fetching groups from Okta API...")
    print(f"  URL: {OKTA_URL}/api/v1/groups")
    url = f"{OKTA_URL}/api/v1/groups"
    headers = _get_okta_headers()
    all_groups = []
    page_count = 0
    while url:
        page_count += 1
        print(f"\n  Fetching page {page_count}...", end=" ", flush=True)
        # Make API request
        response = requests.get(url, headers=headers)
        # Handle rate limiting (429 Too Many Requests)
        if response.status_code == 429:
            reset_time = int(
                response.headers.get("X-Rate-Limit-Reset", str(int(time.time() + 1)))
            sleep_duration = max(reset_time - int(time.time()) + 1, 1)
            print(
                f"\nRate limit hit. Retrying in {sleep_duration}s...",
                end=" ",
                flush=True,
            time.sleep(sleep_duration)
            continue
        # Check for other errors
        if response.status_code != 200:
            print(f"\n\nError: HTTP {response.status_code}")
            print(f"Response: {response.text}")
            sys.exit(1)
        # Parse response
        groups = response.json()
        print(f"found {len(groups)} groups")
        # Process each group
        for group in groups:
            group_id = group.get("id")
            group_name = group.get("profile", {}).get("name", "")
            if not group_id or not group_name:
                print(f"    Warning: Skipping group with missing id or name: {group}")
                continue
            all_groups.append({"id": group_id, "name": group_name})
        # Check for next page (pagination via Link header)
        url = None
        if "link" in response.headers:
            links = response.headers["link"].split(", ")
            for link in links:
                if 'rel="next"' in link:
                    # Extract URL from: <https://...>; rel="next"
                    url = link[link.find("<") + 1 : link.find(">")]
                    break
    print(f"\n✓ Fetched {len(all_groups)} total groups across {page_count} pages")
    return all_groups
def _generate_import_file(groups: list[dict[str, str]]) -> None:
    Generate Terraform import file.
    Args:
        groups: List of group dictionaries
    print("\nGenerating Terraform file...")
    # Ensure output directory exists
    os.makedirs(os.path.dirname(IMPORT_FILE), exist_ok=True)
    with open(IMPORT_FILE, "w") as import_file:
            group_id = group["id"]
            group_name = group["name"]
            # Create resource name from group name
            resource_name = _slugify(group_name)
            # Write import block
            import_file.write("import {\n")
            import_file.write(f'  id = "{group_id}"\n')
            import_file.write(f"  to = okta_group.{resource_name}\n")
            import_file.write("}\n\n")
    print(f"✓ Generated {IMPORT_FILE}")
    print(f"\n✓ Created {len(groups)} import statements")
def main() -> None:
    """Main execution flow."""
    print("=" * 80)
    print("Okta Group Import Generator")
    print("=" * 80)
    # Fetch groups from Okta API
    groups = _fetch_all_groups()
    if not groups:
        print("\nNo groups found. Exiting.")
        sys.exit(0)
    # Generate Terraform file
    _generate_import_file(groups)
    # Success message
    print("\n" + "=" * 80)
    print("SUCCESS")
    print("=" * 80)
    print("\nNext steps:")
    print("  Review the generated file:")
    print(f"   - {IMPORT_FILE}")
if __name__ == "__main__":
    main()
Run it:
python generate_group_imports.py
Now you have import blocks for each ID returned and the script is reproducible and versionable.
Why Naming Strategy Matters
Notice we didn’t use raw IDs as Terraform resource names.
This works:
okta_group.group_00g1abcdXYZ12345
But this is more descriptive and easier to maintain:
One optimizes for speed of import.
The other optimizes for long-term readability.
Neither is universally correct, but it’s important to be intentional about your naming systems.
Step 3: Let Terraform Generate the Configuration
Now we lean on a powerful feature introduced in newer Terraform versions:
terraform plan -generate-config-out=generated_groups.tf
Terraform will:
  • Process the import blocks
  • Query the provider for resource details
  • Generate HCL that matches production
Instead of guessing at arguments, you let the provider declare them.
For a single group, you might see:
resource "okta_group" "engineering" {
  name        = "Engineering"
  description = "Engineering department users"
  custom_profile_attributes = {}
The generated file will likely be very verbose.
That’s expected.
Accuracy matters more than aesthetics at this stage.
Work in Batches
The biggest mistake is trying to import everything at once.
Importing 1,000 resources at once creates a massive, unreadable diff. Instead, work by resource type. It reduces cognitive load and keeps the blast radius of errors small.
In Okta, a logical batching order might look like:
  1. Network Zones: Low volume, high impact.
  2. Auth Policies & Device Posture: The foundation of your security.
  3. Groups & Rules: The identity core.
  4. Applications: The most verbose and complex.
Generate → Review → Commit → Repeat.
Each batch builds confidence.
Refactor Only After Parity
Wait until you reach a clean plan for a resource type before you start cleaning up the code. Once the state matches production exactly, that’s when you can:
  • Standardize resource names.
  • Extract common patterns into modules.
  • Pull hardcoded values into variables.
The Golden Loop:
  1. Generate raw config.
  2. Verify no changes.
  3. Commit.
  4. Refactor.
  5. Verify no changes again.
  6. Commit again.
By separating the “import” phase from the “aesthetic” phase, you ensure that every stylistic change is verified against the live environment.
What Changes After Parity?
Once Terraform reflects reality, something subtle shifts.
Small UI edits start to show up in plan.
You might see:
~ attribute changed
And now you have options:
  • Accept the change and codify it in the Terraform config
  • Revert it with terraform apply
  • Intentionally modify it to something else
Before Terraform, those changes were silent.
Now they’re observable.
That shift alone is often worth the effort.
A Few Things I’ve Learned Along the Way
The process of moving from ClickOps to Code isn’t just a technical migration; it’s an educational one. Here are a few things that have become clear to me during this process:
Generated configuration is noisier than expected
When you let Terraform generate your configuration, it doesn’t just capture the settings you care about. It captures everything. You’ll find default values, deprecated attributes, and internal metadata that you never see in the UI. Sifting through this noise to find the “intent” of a resource is the most time-consuming part of the refactoring phase.
API pagination matters sooner than you think
If you’re writing scripts to generate import blocks, don’t assume a single API call will return everything. In a production Okta environment, “all groups” or “all users” almost always requires handling pagination. Check the API documentation to see if it applies to you on every object you’re trying to import. Failing to do this is silent and you may not even realize you’re missing part of your environment.
API rate limits can be quite harsh
Terraform is fast. APIs are often slower. When you run a plan or apply against hundreds of resources, you will likely hit rate limits. Some systems are stricter than others. Plan accordingly. Implementing exponential backoff in your generation scripts and understanding your provider’s concurrency settings is essential for a smooth workflow.
Naming conventions become very visible
In the UI, a group named “Engineering-Prod-Access” and “engineering_prod_access” might be similar enough visually. In code, those inconsistencies are glaring. This process forces a conversation about naming standards that probably should have happened years ago.
“Temporary” resources are everywhere
Every environment has them: the “test-policy-do-not-delete” from 2022 or the “temp-access-for-contractor” that expired months ago. Terraforming a live system acts as a high-resolution audit. You will find things you forgot existed, and you’ll finally have the visibility needed to delete them.
Closing Thought
Terraforming a live system isn’t about control. It’s about clarity.You’re not rewriting history. You’re documenting what exists and choosing how it evolves.Once the system lives in code, the conversation changes.
It’s no longer:
“Who changed this?”
It becomes:
“Let’s look at the plan.”
That’s the real benefit of going from ClickOps to Code.
Originally posted in Scott Blakes blog, MacAdmins Musings
Chubs
  • Apr 16, 2026 8:13 PM UTC
Most difficult thing is gathering the current state data and making sure it matches before doing an apply.
Unfortunately, my management wants to live in a “hybrid world” where Terraform AND manual manipulation are authoritative.  Just not sustainable TBH.  This has queued me up to look for a UI of sorts to allow for my team members (who are not coders) to be able to pivot swiftly to the platform.
Needless to say, TF isn’t for everyone.
mscottblake
  • Apr 16, 2026 8:55 PM UTC
I think the thing I would focus on in your situation is making it as easy as possible to synchronize GUI changes. I would work to write some scripts that query the API and automatically creates full, idempotent HCL. Eventually, you can get the output perfect and then run it on a schedule.
Chubs
  • May 12, 2026 8:27 PM UTC
All it takes is time...and AI is forcing the hand where time is not accessible.
