Finally upgraded to Lion server....
  • November 9, 2011
  • 5 replies
  • 4 views
I'm pretty sure this issue has been beaten but we've finally upgraded our
sever to 10.7.2 from 10.6.8 and of course the jss is no longer working.
Running 8.1 . Tomcat isnt starting from the Jss. I've manually installed
tomcat and can reach localhost:8080 but no dice 8443. Any help ?
HUGE
Joseph Simon / System Administrator
718 233 4016 / F 718 625 5157
www.hugeinc.com
  • November 9, 2011
HUGE
www.hugeinc.com
bentoms
Forum|alt.badge.img+35
  • November 9, 2011
http://www.jamfsoftware.com/kb/article.php?id=076
Try both the jss util & launchctl commands.. I'm on 8.31 so no sure which to use for lion.
Regards,
Ben.
  • November 9, 2011
I tried this: sudo jssutil startTomcat but no dice.
Im starting to think Tomcat isnt installed anymore. When you check the jss
web application itt doesnt report a tomcat version. Which is why I
installed it manually by downloading the files from the apache site. Anyone
else have suggestions ?
On Wed, Nov 9, 2011 at 3:43 PM, Ben Toms <bentoms at btopenworld.com> wrote:
http://www.jamfsoftware.com/kb/article.php?id=076 Try both the jss util & launchctl commands.. I'm on 8.31 so no sure which to use for lion. Regards, Ben. On 9 Nov 2011, at 20:37, "HUGE | Joseph Simon" <jsimon at hugeinc.com> wrote: I'm pretty sure this issue has been beaten but we've finally upgraded our sever to 10.7.2 from 10.6.8 and of course the jss is no longer working. Running 8.1 . Tomcat isnt starting from the Jss. I've manually installed tomcat and can reach localhost:8080 but no dice 8443. Any help ? -- ... HUGE Joseph Simon / System Administrator 718 233 4016 / F 718 625 5157 www.hugeinc.com
Casper mailing list Casper at list.jamfsoftware.com http://list.jamfsoftware.com/mailman/listinfo/casper
HUGE
www.hugeinc.com
bentoms
  • November 9, 2011
Did you try the launchctl commands?
Regards,
Ben.
  • November 9, 2011
Have you installed Java? Also, have you re-run the JAMF installer?
