Hello to all. I'm using the following naming script to manually rename a computer. I renames the computer fine but it doesn't change the name in JAMF. It still is just listed as "iMac". Any thoughts?
!/bin/bash
sleep 30
RENAME COMPUTER
ComputerName=`/usr/bin/osascript <<EOT
activate
with timeout of 86400 seconds
set ComputerName to text returned of (display dialog "Please Input Computer Name" default answer "" with icon 2)
end timeout
end tell
EOT`
echo $ComputerName
sudo scutil --set HostName $ComputerName
sudo scutil --set LocalHostName $ComputerName
sudo scutil --set ComputerName $ComputerName
echo "Rename Successful"
sudo /usr/local/bin/jamf recon
sleep 10
RUN CASPER POLICIES IN THE FOLLOWING ORDER
sudo jamf policy -event ADBind
sudo jamf policy -event ProgressBarApp
sudo open /Applications/Utilities/ProgressScreen.app
sudo jamf policy -event BaseAppsInstall
sudo jamf policy -event QuitProgressScreen
sudo jamf policy -event ImageSettings
exit -0
