Updating the Preboot Volume After Reissuing FV Key?
  • October 14, 2020
  • 0 replies
  • 75 views
We will be using a script to prompt the users to enter their creds in order to reissue the FileVault key. I read in a post that if the system is apfs then you should also run diskutil apfs updatePreboot / and was wondering if that is actually necessary. I can alter the script without issue however I prefer not to if its not required.
Script I acquired:
https://github.com/jamf/FileVault2_Scripts/blob/master/reissueKey.sh
Post where it mentions running the diskutil cmd:
https://www.jamf.com/jamf-nation/discussions/32500/reissue-filevault-key-when-current-key-is-invalid-mgmt-account-is-enabled-for-fv2
