Safari Homepage button
  • March 24, 2022
  • 16 views
dlondon
Just wondering if there is a way to enable the Safari Homepage button so that it's visible.  I would like to do this on the command line so that I can have Jamf do it
1 reply
  • October 23, 2024
Anyone, is this even a thing? I am looking for the same as OP, but I can't find any config that will make it available in Safari the first time it opens. As of now user has to manually set it.
