Hello!
This might be covered in another form as I am new to the community, But Wanted to bounce this off everyone to see if anyone else has had this issue and how to work around it. I have a computer lab that is hard wired for network, and found students were hooking the wifi to their own personal hotspots and disconnecting the lan cable. This is an issue as it bypasses the web filter, so I disabled Wifi on the machines. The instructors want to use Air-Drop which requires wifi. Is there a way to enable wifi but to not join any networks? Basically have wifi on for Air-drop but not looking for SSID's? I suggested using drop box but they are not a fan maybe a setting in Jamf? Any help?
