Hello,
I am just want to know that why I'm experiencing an issue with SSO via Azure. After configuring the connection as described here: Tutorial we have the following situation: - Logon via the "Test connection"-Button from inside the AAD Application Configuration works as expected. The user is directly signed in and reaches the JamF Pro Dashboard- - Login via Jamf Pro Login (jamfcloud.com) simply redirects to the JamF Pro Logon Page. Is there anything which needs to be done to enable JamF Pro to identify, that the user trying to connect is expected to be a SSO-User? Any hint would be warmly appreciated. PartyCityFeedback Survey
