Problems with 8.21
  • July 28, 2011
  • 27 views
Have any of you seen issues with 8.21? It seems to have broken a few things over here, including mobile device enrollment (hangs at enrolling MDM cert), screen sharing (not just via casper remote, I seem to never have permissions to screen share which was never an issue before), and self-service also seems to require you to authenticate as an admin, regardless of the settings in the JSS.
Any ideas?
Benji Bergstein
Client Strategies
Benji.Bergstein at gianteagle.com<mailto:Benji.Bergstein at gianteagle.com>
412.963.6200 x21386
Forum|alt.badge.img+20
  • July 28, 2011
I also am having MDM errors. According to JAMF we need a new cert, however we share a DUNS number with another group and they are lagging with getting us the cert we need so I can't test the MDM solution yet.
Matt Lee, CCA/ACMT/ACPT/ACDT
Senior IT Analyst / Desktop Architecture Team / Apple S.M.E / JAMF Casper Administrator
Fox Networks Group
  • July 28, 2011
We've been using the built-in CA, and it still doesn't work, even if we update the cert. Leads me to believe theres something funky going on...
  • July 28, 2011
Benji,
We've been having the same trouble with the screen sharing and it appears to
only happen for accounts added into the JSS using a group from LDAP. You can
work around this by adding your accounts individually.
*Victor Escala *| Technical Support Specialist | lynda.com, Inc. | 6410 Via
Real | Carpinteria, CA 93013 | 805.477.3900 office | 786.351.6398 mobile | *
