Jamf Push Proxy returned status of: 403
  • November 15, 2018
  • 16 views
Curious if any environments are still seeing these types of errors running 10.8?
ThijsX
Forum|alt.badge.img+20
  • Employee
  • November 21, 2018
@lashomb Hi,
I have not seen the 403 for a while, current build : 10.8.0-t1539715549
When the 403 appeared, i deleted the Push Proxy Certificate and recreated.
  • January 22, 2019
Yes we are seeing these warning in our environment. It is occupying our logs completely
  • January 22, 2019
Try to contact JAMF support, the issue causing these is supposed to be fixed, but 'old' notifications are probably still in the queue, causing these errors. Or you could go through the steps below, which JAMF support gave me.
BE AWARE! DO THIS AT YOUR OWN RISK!
To verify whether we are hitting the PI, let's run the following query in the database: 1. SELECT server_identifier FROM push_notification_proxy_settings; LRpddSTgisziLG8jaO6S SELECT COUNT(*) FROM app_push_notification_queue WHERE push_content NOT LIKE "%XXX-XXX-XXX-XXX-XXXX%"; To remove old notifications: 1. run query: DELETE FROM app_push_notification_queue WHERE push_content NOT LIKE "%XXX-XXX-XXX-XXX-XXXX%"; 4hCCIaxyokaY1U1IvyC2 We should now be good to go and not seeing the errors in our logs any longer.
