Ok, I give. Any suggestions on a way to create a smart group that is for machines that are less than 90 days since last report. You can create groups with "More than X days", but not the other way around. I have a need to be able to create groups for reporting reasons of active machines. I can put in specific dates, but I don’t want to have to redefine the group every time I need the report run. This seems like it should be easy, if JAMF put in a more than, there should be a less than. Any Suggestions?
Thanks
Paul Austin
End User Computing, Platform Engineering
Wells Fargo | 1525 West W.T. Harris Blvd | Charlotte, NC 28262
MAC D1112-036
Tel 704 427-0903
