I'm in the process of integrating some Macs into our predominately Windows
(AD) environment. For some reason, the HPC guys decided that they'd set up
an LDAP server of their own when they set up their Linux-based systems
rather than work to get Unix extensions into our existing AD environment.
I have next to no knowledge of AD. I'm wondering whether to integrate my
Macs into the existing Windows AD infrastructure, or hook into the
alternative LDAP server. For those that have been through these cycles,
could you tell me what the least painful route would be, and the pros/cons
of each?
I've read through the Apple whitepaper on AD integration and it implies
it's a very simplistic process, is that really the case in practice? Can I just plug Macs straight in, or is a third part plugin like Centrify recommended?
Thanks for any advice.
