neat! just ran a sudo command in terminal on a 10.10.5 machine...
$ sudo jamf removeSWUSettings We trust you have received the usual lecture from the local System Administrator. It usually boils down to these three things: #1) Respect the privacy of others. #2) Think before you type. #3) With great power comes great responsibility. Password:
Hasn't that been the text that displays the first time sudo is used for a long time?
I've never noticed it. Had it happen on 2 different systems.
It's been there since before day one (Dev preview, etc). I still smile when I see it. :-)
It's been there for first time sudo since 10.0.
I noticed this myself over the weekend. Thought to myself "Is that a blast from the past that just made a reappearance? Or has it been there all along and my brain is fogged?"
I'm on a Mavericks system at the moment and it isn't there.
That's the standard dialog that comes up the first time sudo is used. The reason it's making a reappearance is that Apple updated.to a new version of sudo as part of the security fixes in 10.10.5:
https://support.apple.com/HT205031
With new sudo, comes new sudo warning.
Glad it's back. I missed that little bit of humor. I'm sure it will be removed soon enough.
Be warned: on my own system I edited the /etc/sudoers file, and this file was back to default after the 10.10.5 update. Now I understand why.
