@PCalomeni wrote:
- Manual Update Workflow for App Installers
 Jamf Pro now includes a manual update workflow for App Installers. This change gives you more control over the App Installers deployments in your environment by allowing you to test a version on a small group of computers before applying it to all computers.
Just to clarify, if you change this to Manual, will the Update Deadline settings be based on when a new version is approved by the IT admins in Jamf?
            @McAwesome yes, all of the end user experience settings that you have configured for a particular App Installers deployment, including the update deadline, are applied to the version of a software title that was approved by a Jamf Pro Admin.
            @JustinC I was more meaning something like if you have your deadline set for 5 days after the update is made available, is it going to apply to 5 days after the update is approved by IT or after it gets released by Jamf?
            As a continued note, those of us in the cloud with Custom URLs cannot apply the update manually... oh the things we wish we'd been told during the migration engagements.
            @McAwesome it is counted from the moment the installer is delivered to the computer and the included LaunchDaemon is started. So even for every computer in the same smart group it will mean a slightly different moment - 5 days from the moment the installer is downloaded and launched.
I'm just reading the 11.2 release notes and I'm confused about the line
"When a computer enrolls via a PreStage enrollment and the Jamf management account is also set to be created during enrollment, the jamf binary will create the account after the first user logs in."
Our prestage (we only have 1) has the option set 'Create a local administrator account before the Setup Assistant' which makes a 'jamfmgmt' account, it's been like this since we first had JAMF set up by the consultant. It's my understanding that that is the account which JAMF uses to run policies.
When we set up a new computer our own 'admin' account is made via a script and all of our install policies run before anyone ever logs into the computer ... if our jamfmgmt account is not made until somebody logs in does this mean that no policies can run before that time? If so that would make deploying large numbers of machines at once a lot harder all of a sudden!
Ian
            @ianatkinson Thanks for your question. The management account is not needed to run any policies, so your current workflow will continue to work with this change.
            @MattAebly thank you for clarifying, out of interest then what does that local admin account do?
I asked our onboarding consultant about it a couple of years ago and he said
I hope you are well, the naming of this account is irrelevant I have just always used jamfmgmt but what this does is this creates a hidden account on the machine which allows the machine to talk back to Jamf,  it runs policies and escalates privileges to root, this is not the local admin account you will need to add that one as part of the Prestage or via a policy after enrolment.
...but you're suggesting it's not needed to run policies, that leaves me wondering what the purpose is? I may have misunderstood it for a number of years!
            @MattAebly How will this affect situations involving required logins to set up devices?
In our Mac labs here we use said management account to login automatically to run the software policies and escrow tokens. this change will create issues involving this if my reading of it is correct.
            @ianatkinson @WayneHelios  I'm pretty sure they're referring to the management account in Settings -> User-initiated enrollment -> Create management account. This is separate from the account created during prestage.
            When is the automated cloud upgrades scheduled for now?
            @andrewsp the notes say "via a PreStage enrollment " I wouldn't have thought that referred to the user initiated enrollment as it's a different thing isn't it? Or I may just be confused at this point! :)
            Unfortunately, there is an annoying bug in this version.
The value set in the "Account Preferences > Language & Region > Language" is overridden by the browser settings when logging in.
Example:
On a German macOS, Jamf Pro is displayed in German, although English is set in the "Account Preferences"! (This has worked with all previous versions so far).
You cannot define the language in Safari, the language is always taken from the system.
In Google Chrome you can define the language independently of the system. So if I define English in Google Chrome, Jamf Pro is also in English.
But I want the "Account Preferences" to control the language in Jamf Pro, regardless of the browser or system language.
(If you set the language in Jamf Pro from English to German and immediately switch back to English, then this will be applied correctly. However, this only applies to the current session. The next time you log in in Jamf Pro, the browser/system language will apply again).
            @ianatkinson if you read the description on that screenshot it indicates it’s used for both prestage enrollment and user initiated enrollment. It’s confusing since it’s on the user initiated enrollment settings.
            @mapi_sk
For me the same question -> "When is the automated cloud upgrades scheduled for now?"
            Thank you for asking mapi_sk and @PE14_2. Cloud upgrades are scheduled for the weekend of 16–17 February.
            @hansjoerg_watzl, Thanks for the feedback and bringing this to our attention. Our team is already preparing a fix for this issue and will be delivering it soon in an upcoming version. Please reach out if you have any other questions or concerns.
