Jamf Connect 2.35.0 Now Available
  • May 13, 2024
  • 0 replies
  • 48 views
PCalomeni
Today we released Jamf Connect 2.35.0. This release includes the following changes and improvements:
  • The new URL Scheme and Command Line Elevation (URLCommandLineElevation) key prevents unsanctioned privilege elevation via URL schemes and the command line interface. Elevation from the command line interface is only allowed when URL Scheme and Command Line Elevation is set to true.
  • The ZIP file from the Collect logs button now includes the com.jamf.connect.actions and com.jamf.connect.shares domains.
Resolved Issues
  • [PI116170] The Jamf Connect login window now informs users their account is locked after multiple failures to enter the correct password on computers without FileVault encryption.
  • [PI117370] Configurations of the Jamf Connect menu bar app with Kerberos no longer experience password expiration timers not resetting after a user successfully changes their password.
  • [PI117524] Jamf Connect will now notify users when a privilege elevation denial occurs due to local time tampering.
To access new versions of Jamf Connect, log in to Jamf Account with your Jamf ID. The latest version is located in the Products section under Jamf Connect.
Product Documentation
For additional information on what's included in this release, review the release notes via the Jamf Learning Hub.
Thank you!
The Jamf Connect team
