Jamf Pro 11.5.1 Now Available
  • May 23, 2024
  • 0 replies
  • 30 views
PCalomeni
Today we are releasing a maintenance version of Jamf Pro; this release includes the following changes and improvements:
Support Added for Deploying Apps Using the Jamf Certificate SDK
You can now deploy apps that use the Jamf Certificate SDK to personally owned mobile devices, including iOS, iPadOS, and visionOS devices. Previously only institutionally owned iOS devices were supported.
Important Notice
Cloud Service Connection Manual Initialization—Starting in August 2024, if you have Jamf Pro 11.3.0 or earlier, you must upgrade to Jamf Pro 11.4.0 or later to initialize a Cloud Services connection manually. After upgrading to Jamf Pro 11.4.0 or later, you can enable a Cloud Services connection in Jamf Pro. For more information, see Cloud Services Connection in the Jamf Pro Documentation. If you already have a Cloud Services connection enabled, you will not need to take any action.
Resolved Issues
Jamf Pro Server
  • [PI118234] Text in the Socket Filter Designated Requirement section of Content Filter payloads no longer appears garbled when viewing the contents of the payload after clicking Save.
  • [PI118457] Failure to install a Jamf Remote Assist Privacy Preferences Policy Control (PPPC) configuration profile no longer produces looping errors while devices are being registered.
For additional information on what's included in this release, review the release notes via the Jamf Learning Hub.
To access new versions of Jamf Pro, log into Jamf Account with your Jamf ID. The latest version is located in the Products section under Jamf Pro.
Cloud Upgrade Schedule
Your Jamf Pro server, including any free sandbox environments, will be updated to Jamf Pro 11.5.1 based on your hosted data region below. Review this guide if you need assistance identifying the Hosted Data Region of your Jamf Cloud instance.
If you would like to upgrade manually, navigate to https://account.jamf.com/products/jamf-pro and click Upgrade (Standard Cloud) or Schedule Upgrade (Premium Cloud) at the top of the page.
Subscribe to product alerts to receive real-time updates.
Hosted Region Begins Ends
ap-southeast-2 31 May at 1400 UTC 31 May at 2300 UTC
ap-northeast-1 31 May at 1500 UTC 1 June at 0100 UTC
eu-central-1 31 May at 2200 UTC 1 June at 0900 UTC
eu-west-2 31 May at 2300 UTC 1 June at 0600 UTC
us-east-2 1 June at 0400 UTC 1 June at 1700 UTC
us-west-2 1 June at 0700 UTC 1 June at 2000 UTC
