Jamf Pro 11.13 Now Available
  • January 21, 2025
  • 70 views
PCalomeni
Today we are releasing Jamf Pro 11.13; highlights include:
  • Admin SSO
    Administrators can use Admin SSO as a single sign-on (SSO) method to log in to Jamf Pro. Admin SSO, configured in Jamf Account, allows you to use a centralized configuration for each Jamf product instead of separate single sign-on integrations. Admin SSO allows you to log into Jamf Account using either a cloud-based identity provider (IdP) or your Jamf ID.
  • Self Service+
    Self Service+ is an enhancement to the Self Service end user application for macOS that allows users to access content and updates that have been preconfigured in Jamf Pro. Using Self Service+, end users can now view security status via the home screen's Security dashboard if Jamf Protect is installed on the device.
For additional information on what's included in this release, review the release notes via the Jamf Learning Hub. See the latest release notes video for a brief overview of new features and enhancements.
To access new versions of Jamf Pro, log into Jamf Account with your Jamf ID. The latest version is located in the Products section under Jamf Pro.
Cloud Upgrade Schedule
Your Jamf Pro server, including any free sandbox environments, will be updated to Jamf Pro 11.13.1 based on your hosted data region below. Review this guide if you need assistance identifying the Hosted Data Region of your Jamf Cloud instance.
If you would like to upgrade manually, log in to Jamf Account and select Jamf Pro Info >; click Upgrade on the appropriate instance. Note: This capability is not available for GovCloud environments and is disabled for all instances one day prior to when the scheduled standard upgrades begin.
Subscribe to product alerts to receive real-time updates.
Hosted Region Begins Ends
ap-southeast-2 31 January at 1300 UTC 31 January at 1900 UTC
ap-northeast-1 31 January at 1500 UTC 31 January at 2300 UTC
eu-central-1 31 January at 2300 UTC 1 February at 1000 UTC
eu-west-2 1 February at 0000 UTC 1 February at 0700 UTC
us-east-2 1 February at 0500 UTC 1 February at 1500 UTC
us-west-2 1 February at 0800 UTC 1 February at 1900 UTC
dletkeman
  • January 21, 2025
No release video?
PCalomeni
  • Community Manager
  • January 21, 2025
@dletkeman The release notes video has been posted. Thanks for your patience!
karthikeyan_mac
Forum|alt.badge.img+20
Excited for Self Service+.
