Jamf Connect 2.28.1 Now Available
  • October 16, 2023
  • 0 replies
  • 18 views
PCalomeni
Today we are releasing a maintenance version of Jamf Connect. Jamf Connect 2.28.1 addresses the following product issues:
  • [CON-4909] The Jamf Connect menu bar app no longer repeatedly requests background account validation while changing networks.
  • [PI113084] The Jamf Connect menu bar app's user agent string header now includes the user's platform. Conditional Access policies should be updated accordingly if they are set to conduct checks based on user agent strings. For example, Jamf%20Connect/5224 CFNetwork/1474.1 Darwin/23.0.0 will now appear as JamfConnect/5224 CFNetwork/macOS/1474.1 Darwin/23.0.0.
To access new versions of Jamf Connect, log in to Jamf Account with your Jamf ID. The latest version is located in the Products section under Jamf Connect.
Product Documentation
For additional information on what's included in this release, review the release notes via the Jamf Learning Hub.
Thank you!
The Jamf Connect team
