Jamf Pro 11.18.1 Now Available
  • July 3, 2025
  • 695 views
PCalomeni
Today we are releasing a maintenance version of Jamf Pro; highlights include:
Changes and Improvements
  • Jamf has upgraded the Jamf Support ticketing system. To access the new Support portal, log in to Jamf Account and click Contact Support in the top navigation.
  • Jamf Pro no longer returns a "Version entered is unknown" error when attempting to execute an advanced computer search or save a smart computer group that uses 'unknown version' as a value for existing patch reporting criteria.
Resolved Issues
Jamf Pro Server: Security Issue
Jamf provides the CVE-ID for security issues with high or critical severity when possible.
[PI136944] Jamf Pro 11.18.1 includes Tomcat 10.1.42, effectively resolving a known security vulnerability in a third-party library (CVE-2025-48976).
For additional information on what's included in this release, review the release notes via the Jamf Learning Hub.
To access new versions of Jamf Pro, log into Jamf Account with your Jamf ID. The latest version is located in the Solutions section under Jamf Pro.
Cloud Upgrade Schedule
Your Jamf Pro server, including any free sandbox environments, will be updated based on your hosted data region below. Review this guide if you need assistance identifying the Hosted Data Region of your Jamf Cloud instance.
To upgrade manually: Log in to Jamf Account, click View details on the Jamf Pro tile, and then click Upgrade on the appropriate instance. Note: This capability is not available for GovCloud environments and is disabled for all instances one day prior to when the scheduled standard upgrades begin.
Subscribe to product alerts to receive real-time updates.
Hosted Region Begins Ends
ap-southeast-2 11 July at 1400 UTC 11 July at 2000 UTC
ap-northeast-1 11 July at 1500 UTC 11 July at 2300 UTC
eu-central-1 11 July at 2200 UTC 12 July at 0900 UTC
eu-west-2 11 July at 2300 UTC 12 July at 0600 UTC
us-east-1 StateRAMP 12 July at 0400 UTC 12 July at 1400 UTC
us-east-2 12 July at 0400 UTC 12 July at 1400 UTC
central-us Azure 12 July at 0500 UTC 12 July at 0700 UTC
us-west-2 12 July at 0700 UTC 12 July at 1800 UTC
brandonharshe
  • July 7, 2025
@PCalomeni It seems that us-east-1 is not included in the chart.
PCalomeni
  • Community Manager
  • July 7, 2025
@brandonharshe Thanks for reaching out. “us-east-1 StateRAMP” is a more accurate description of what we previously referred to as “us-east-1” in the Cloud Upgrade Schedule.
