Jamf Pro 11.24 Now Available
  • January 20, 2026
  • 1027 views
PCalomeni
Today we are releasing Jamf Pro 11.24; highlights include:
  • OIDC-based SSO Through Jamf Account Enabled by Default for New Jamf Pro Instances
    All new cloud-hosted Jamf Pro instances are pre-configured to use OIDC-based single sign-on (SSO) through Jamf Account as the default authentication method for first-time access. This eliminates several steps of the Jamf Pro setup workflow and also ensures that new Jamf Pro instances have access to platform capabilities (e.g., blueprints and compliance benchmarks) immediately after setup.
    Note: This change only affects newly created Jamf Pro instances hosted in Jamf Cloud (not available for Jamf Premium Cloud Plus or StateRAMP environments).
  • Automatic Jamf Protect Tenant Registration
    Jamf Pro can now automatically register your organization's Jamf Protect tenant to establish a secure connection between Jamf Pro and Jamf Protect. This eliminates the need to manually integrate by creating an API Client in Jamf Protect and configuring connection settings in Jamf Pro.
  • Improved Declarative Device Management for Migrated Instances
    Jamf Pro now automatically initializes declarative device management organization information immediately after on-premise instances are migrated to Jamf Cloud. This change ensures organization information is complete, eliminating migration failures.
For additional information on what's included in this release, review the release notes via the Jamf Learning Hub.
To access new versions of Jamf Pro, log into Jamf Account with your Jamf ID. The latest version is located in the Solutions section under Jamf Pro.
Cloud Upgrade Schedule
Your Jamf Pro server, including any free sandbox environments, will be updated based on your hosted data region below. Review this guide if you need assistance identifying the Hosted Data Region of your Jamf Cloud instance.
To upgrade manually: Log in to Jamf Account, click View details on the Jamf Pro tile, and then click Upgrade on the appropriate instance. Note: This capability is not available for GovCloud environments and is disabled for all instances one day prior to when the scheduled standard upgrades begin.
Subscribe to product alerts to receive real-time updates.
Hosted Region Begins Ends
ap-southeast-2 30 January at 1300 UTC 30 January at 1900 UTC
ap-northeast-1 30 January at 1500 UTC 30 January at 2300 UTC
eu-central-1 30 January at 2300 UTC 31 January at 1000 UTC
germanywestcentral Azure 30 January at 2300 UTC 31 January at 0100 UTC
eu-west-2 31 January at 0000 UTC 31 January at 0700 UTC
us-east-1 StateRAMP 31 January at 0500 UTC 31 January at 0900 UTC
us-east-2 31 January at 0500 UTC 31 January at 1400 UTC
central-us Azure 31 January at 0600 UTC 31 January at 0800 UTC
us-west-2 31 January at 0800 UTC 31 January at 1900 UTC
1 reply
Jordy-Thery
Forum|alt.badge.img+15
  • January 20, 2026
This is nice. 👌🏻
