Blog
You Still Use a Printer?
  • March 16, 2023
  • 7 replies
  • 194 views
golbiga
Forum|alt.badge.img+21
Recently, a customer inquired about whether macOS can block AirPrint via a configuration profile. Unfortunately for the customer, the allowAirPrint restriction is iOS only (https://jamf.it/jpRgP). Because it can't be blocked, I decided to look into how to Jamf Protect could be used to report on print usage in macOS.
Jamf Protect
Jamf Protect offers the following for generating alerts on a macOS endpoint:
  • Threat Prevention
  • Analytics
  • Unified Logs
  • Telemetry
  • Device Controls
Threat Prevention and Device Controls are out of scope for this use case, so let’s take a look at Telemetry, Unified Logs, and Analytics.
Jamf Protect Telemetry
Telemetry is a new feature in Jamf Protect that allows customers to send audit events generated on their macOS devices to their SIEM of choice. Telemetry currently uses the BSM implementation in macOS, so I can use the pre-existing binaries that I would normally use to analyze the logs locally.
Running sudo praudit -sx /dev/auditpipe in Terminal does show print events, however none of this data would be useful for this exercise.
<record version="11" event="AUE_ssauthorize" modifier="0" time="Tue Feb 14 22:14:04 2023" msec=" + 143 msec" > <subject audit-uid="allen.golbig" uid="allen.golbig" gid="staff" ruid="allen.golbig" rgid="staff" pid="2578" sid="100013" tid="6357 0.0.0.0" /> <text>system.print.admin</text> <text>client /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/printtool</text> <text>creator /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/printtool</text> <return errval="success" retval="0" /> <identity signer-type="1" signing-id="com.apple.authd" signing-id-truncated="no" team-id="" team-id-truncated="no" cdhash="0x1cb1be1d7de2da830093598ce3361797ce861fe3" /> </record>
Unified Logs
Unified Logs (UL) are the logging API in macOS that replaced the Apple System Log (ASL) back in macOS 10.12. In Jamf Protect, customers are able to add Unified Log predicates (default level only), which generate alerts when triggered. Much like Telemetry, Unified Log events must be sent to a customer’s SIEM. Because the macOS printing system is built off of the Common Unix Printing System (CUPS), I figured that’s where I should start.
log stream --predicate 'eventMessage contains "cupsd"' spits out a ton of information, but nothing that I can filter with Jamf Protect to generate an alert. My Jamf Protect plan log level is set to verbose (which you normally shouldn't leave on), but it gave me a clue where to look next.
[com.jamf.protect.daemon:Process] Checking: EXEC: (17100) cupsd
Jamf Protect Analytics
Analytics are the behavioral detections in Jamf Protect. When triggered, these events are sent to both Jamf Protect and/or your SIEM. Jamf provides well over 150 built-in analytics, but we’re also able to create custom analytics to trigger alerts for events just like these. Before we go into the NSPredicate and NSExpression that I ended up using, let’s go over how I took that Unified Log message and figured out what exactly to look for.
There are many apps (free) which you can use to monitor Process events in macOS:
For this write-up I'm going to use ESFPlayground. After creating a blank text file (gotta conserve that toner), I’m going to launch ESFPlayground and keep an eye out as I print the blank doc. The first thing I noticed was that I generated seven, yes seven ES_EVENT_TYPE_NOTIFY_EXEC events. Looking closer, only one of them had a process_path I wanted, /usr/libexec/cups/backend/socket:
{ "event" : "ES_EVENT_TYPE_NOTIFY_EXEC", "process" : { "session_id" : 70982, "ruid" : 0, "uid" : 0, "euid" : 0, "tty" : "None", "ppid" : 70982, "path" : "/usr/libexec/cups/backend/socket", "responsible_pid" : 70982, "username" : "root", "command" : " socket://BRN30055C300D7A.local.:9100/ 150 allen.golbig test 1 AP_ColorMatchingMode=AP_ApplicationColorMatching AP_D_InputSlot= nocollate ColorModel=Gray com.apple.print.DialogDismissedBy=Print com.apple.print.DocumentTicket.PMSpoolFormat=application/pdf com.apple.print.JobInfo.PMApplicationName=TextEdit com.apple.print.JobInfo.PMJobName=test com.apple.print.JobInfo.PMJobOwner=allen.golbig com.apple.print.PageToPaperMappingMediaName=Letter com.apple.print.PageToPaperMappingType..n.=1 com.apple.print.PDEsUsed=TextEdit com.apple.print.PrinterInfo.PMColorDeviceID..n.=27237 com.apple.print.PrintSettings.PMColorSpaceModel..n.=1 com.apple.print.PrintSettings.PMCopies..n.=1 com.apple.print.PrintSettings.PMCopyCollate..b. com.apple.print.PrintSettings.PMDestinationType..n.=1 com.apple.print.PrintSettings.PMDuplexing..n.=1 com.apple.print.PrintSettings.PMFirstPage..n.=1 com.apple.print.PrintSettings.PMLastPage..n.=2147483647 com.apple.print.PrintSettings.PMPageRange..a.0..n.=1 com.apple.print.PrintSettings.PMPageRange..a.1..n.=2147483647 com.apple.print.totalPages..n.=1 DestinationPrinterID=Brother_HL_2270DW_series media=Letter PaperInfoIsSuggested..b. pserrorhandler-requested=standard job-uuid=urn:uuid:0cb6a68a-5fbb-3a19-7522-64b9aef4b512 job-originating-host-name=localhost date-time-at-creation= date-time-at-processing= time-at-creation=1676433636 time-at-processing=1676433636 document-name-supplied=test job-impressions=1 com.apple.print.PrintSettings.PMTotalSidesImaged..n.=1 sides=one-sided Duplex=None com.apple.print.PrintSettings.PMTotalBeginPages..n.=1 PageSize=Letter", "team_id" : "", "pid" : 71070, "original_ppid" : 70982, "pgid" : 71070 }, "timestamp" : "2023-02-14 23:00:37" }
I’ll need the signing info for both the process and parent_process now. Running codesign -dv /usr/libexec/cups/backend/socket, I get the following:
Executable=/usr/libexec/cups/backend/socket Identifier=com.apple.socket Format=Mach-O universal (x86_64 arm64e) CodeDirectory v=20400 size=713 flags=0x0(none) hashes=17+2 location=embedded Platform identifier=14 Signature size=4442 Signed Time=Feb 10, 2023 at 12:51:37 PM Info.plist=not bound TeamIdentifier=not set Sealed Resources=none Internal requirements count=1 size=64
Because this is a printing process, cupsd is the obvious parent_process, running pgrep cupsd outputs 70982, which matches the ppid in the ESFPlaygound output above. Let’s grab the codesign info from /usr/sbin/cupsd.
Executable=/usr/sbin/cupsd Identifier=com.apple.cupsd Format=Mach-O universal (x86_64 arm64e) CodeDirectory v=20400 size=3560 flags=0x0(none) hashes=106+2 location=embedded Platform identifier=14 Signature size=4442 Signed Time=Dec 17, 2022 at 2:38:11 AM Info.plist=not bound TeamIdentifier=not set Sealed Resources=none Internal requirements count=1 size=64
Note: If you aren’t sure what the parent_process is for an event, you can use another great app, TrueTree (https://themittenmac.com/the-truetree-concept/). For this example when I run the TrueTree binary shortly after printing, I can search for that ppid
/System/Library/LaunchDaemons/org.cups.cupsd.plist /usr/sbin/cupsd 70982
With both identifiers I can build out a simple custom process event analytic:
$event.type == 1 AND $event.process.signingInfo.appid == "com.apple.socket" $event.process.responsible.signingInfo.appid == "com.apple.cupsd"
One last thing before checking alerts in Jamf Protect. In the ESFPlayground output, under process_command there was a very long string of text. This is the command line output that the socket binary passes when sending a print job. There will be a lot of useful data contained in that string and that’s where Context Items come into play. Context Items are optional values in Analytics which help define additional conditions that an analytic can evaluate.
Name: print job command Type: String Expression: event.process.commandLine
Not Everyone Uses a Brother Printer?
I shared this analytic with a few folks to test and it worked perfectly for them, as long as they had the same brand printer as mine.
In macOS a printer can be added using the following protocols via System Settings:
  • Internet Printing Protocol (IPP)
  • Line Printer Daemon (LPD)
  • HP Jetdirect - Socket
  • AirPrint (combination of IPP and printer discovery)
  • USB
I’ll need to modify $event.process.signingInfo.appid to an array so the analytic can take into account other printing protocols. Running the following from /usr/libexec/cups/backend, I get the list of identifiers:
# Switch to root sudo -s # Run for loop to grab identifiers for i in /usr/libexec/cups/backend/*; do codesign -dv $i 2>&1 | awk -F'=' '/^Identifier/ {print $2}'; done com.apple.bluetooth com.apple.dnssd com.apple.ipp com.apple.ipp com.apple.ipp com.apple.ipp com.apple.dnssd com.apple.lpd com.apple.dnssd com.apple.riousbprint com.apple.smb com.apple.snmp com.apple.socket com.apple.usb
The following identifiers are what I need to have in my custom analytic:
  • com.apple.socket
  • com.apple.ipp
  • com.apple.lpd
  • com.apple.usb
After adjusting the analytic to take into account the additional protocols, it should look like:
$event.type == 1 AND $event.process.signingInfo.appid IN {'com.apple.socket', 'com.apple.ipp', 'com.apple.lpd', 'com.apple.usb'} AND $event.process.responsible.signingInfo.appid == "com.apple.cupsd"
Here is what the final analytic should look like in Jamf Protect:
Finally, let’s take a look at what an alert will look like in Jamf Protect:
SIEM Example
Now that we have our analytic created and assigned to our Jamf Protect Plan, let’s see what an alert would look like in a SIEM if configured in your action configuration. Below is an example query that I’m currently kicking around for querying the alert data in Splunk, along with a screenshot of the data sent from the alert shown above.
index="jamfprotect" input.host.hostname=* input.eventType="GPProcessEvent" input.match.facts{}.name="Printer_Activity" | eval time=strftime(_time, "%m-%d-%Y %H:%M:%S") | eval address = mvindex('args',0) | eval user = mvindex('args',2) | eval file = mvindex('args',3) | rex field="input.match.context{}.value" "DestinationPrinterID\\=(?<printer>[\\w]+...)\\s" | rex field="input.match.context{}.value" "PMApplicationName\\=(?<responsible_application>[\\w]+...)\\s" | table time, user, file, printer, address, responsible_application
GitHub Repo
To find the printer activity custom analytic and more, head over to the Jamf Protect Open Source Repository on GitHub. Within the repo are resources that can be adapted to any Jamf Protect tenant for the following areas, and more:
  • Custom Analytics
  • Unified Log Filters
  • Jamf Protect API Scripts
  • SOAR Playbooks
  • Third Party Integrations
  • Jamf Pro Extension Attributes
Happy printing!
  • Employee
  • March 16, 2023
Love your process!
rastogisagar123
One of the best use case I have ever seen using Jamf Protect. Kudos to you Golbiga!!
ThijsX
Forum|alt.badge.img+20
  • Employee
  • March 17, 2023
Great write up buddy!
  • Employee
  • March 17, 2023
Fantastic work!
garybidwell
  • March 17, 2023
We've had this in use now for the last couple of weeks and been a game changer for our Inside Risk team in gaining visibility to what being printed from our macOS devices.
It's a big thank you from us in creating this.
rlegg
  • Employee
  • March 17, 2023
Great write up! Love seeing the thought process you went through.
ThomasBosboom
  • April 12, 2023
Thanks for the great write-up!
