If you are looking to manage a fleet of Apple devices at scale, Jamf Pro Cloud is one of the
leading tools out there. Whether you are handling Mac, iPads, iPhones, or even Apple TVs, the
cloud-hosted version of Jamf Pro makes setup and ongoing management so much easier, no on-premise servers, no manual patching, and security managed by the experts at Jamf. Below, I
break down the main steps to get up and running with Jamf Pro Cloud, share key concepts,
real-world workflows, and actionable tips.
Table of Contents
1. What is Jamf Pro Cloud?
2. How to Implement Jamf Pro Cloud
3. Core Concepts Explained
  • Policies
  • Configuration Profiles
  • Smart and Static Groups
  • Extension Attributes
  • Scripts
  • App and Patch Management
  • The Self Service Portal
  • Inventory and Reporting
  • Security and Compliance
  • Integrations and Automation
4. Example Workflows
5. Best Practices
Jamf Pro Cloud is a fully cloud-based platform for managing Apple devices. Everything runs
over the internet; you simply log in to a secure portal. Jamf handles all the server infrastructure,
keeps the software up-to-date, and looks after security, so you can focus on managing your
devices, not worrying about server maintenance or downtime.
It’s also built to scale. Whether your organization is just starting with a few test devices or you
need to manage thousands of Apple devices worldwide, Jamf Pro Cloud has you covered.
Step 1: Provisioning Your Jamf Cloud Instance
Your first step is working with Jamf directly, or through a certified partner, to purchase a Jamf
Pro Cloud. Once the paperwork’s complete, Jamf will spin up a dedicated environment for your
company, with its own web address and admin credentials.
Step 2: First Login and Initial Setup
After you receive your unique URL, log in and walk through the setup assistant:
  • Accept the license agreement.
  • Enter your activation code.
  • Set up the main admin account.
  • Confirm what your Jamf Pro Cloud URL will be; this matters because your managed devices check in to this address.
Step 3: Core Configuration
A few key things to set up right away:
  • Inventory Collection: Decide how often Jamf will collect hardware and software data from devices. Too frequent eats bandwidth, too infrequent means stale data.
  • Check-in Interval: A typical value is every 15 minutes, but you can adjust.
  • Set Up a Cloud Distribution Point: Use Amazon S3 or Azure for apps and packages.
  • Configure SSO: If you have identity management (like Okta, Entra ID), hook up SingleSign-On and role-based access for admins.
Step 4: Integrating with Apple
To make life easier, connect to Apple Business Manager or Apple School Manager. This
enables automated, zero-touch enrollment for new devices. Also, set up Apple’s Volume
Purchase Program (VPP), which makes deploying App Store apps a snap right from the Jamf
dashboard.
Step 5: Enrolling Devices
There are two main ways to bring devices into Jamf:
  • Automated Enrollment: Devices purchased via Apple Business Manager can be enrolled automatically just take it out of the box and turn it on.
  • User-Initiated Enrollment: For older devices or unique situations, you can give users a special enrollment URL.
Step six: Ongoing Management
With everything in place, you are ready to start grouping devices, pushing policies and profiles,
deploying apps, and keeping your Apple ecosystem in tip-top shape.
Policies: Policies automate common tasks like software installation, security patching, applying scripts, or enforcing settings. You can trigger them based on scheduled events (like “at every check-in”) or things like network change, and they are always targeted to the right group of devices.
Configuration Profiles: Profiles are like blueprints for device settings. They enforce Wi-Fi, VPN, security restrictions, certificates, and more. You can assign them to devices, users, or groups.
It’s the most powerful way to keep settings consistent and secure across your Apple fleet.
Groups: Smart vs Static
There are two main types of device groups in Jamf:
Smart Groups: These are dynamic and update automatically based on logic you define. For example,
“Mac restarted after 30 days, ” or “devices with SIP disabled.” Great for compliance and automation.
Static Groups: Here, you just add devices manually perfect for pilot testing, special projects, or ad-hoc tasks.
Group Type:  Smart Group
What It Does:  Auto-populates based on criteria Compliance
When to Use: Compliance, automated workflows
Group Type: Static Group
What It Does: Devices added by admin, fixed list
When to Use: Testing, manual or one-off actions
More Key Concepts
  • Extension Attributes: Custom data points you define, letting you collect info not available by default.
  • Scripts: Bash, Python, or other scripts you want to deploy and run on target devices.
  • App & Patch Management: Deploy or update both App Store and custom apps.
  • Self Service Portal: An app on user devices that lets staff install approved software, run scripts, or access how-tos.
  • Inventory & Reporting: Jamf continuously collects inventory and gives you robust reporting to meet any audit or management question.
  • Security & Compliance: Enforce device encryption, compliance rules, and respond tsecurity threats centrally.
  • Integrations & Automation: Jamf with ticketing, identity management, and automation tools to streamline IT workflows.
Custom data fields (script- or user-generated) for inventory details not collected by default.
Useful for tracking, reporting, and targeting based on custom device attributes.
Scripts
Shell/Bash scripts automate advanced tasks: remediation, troubleshooting, or settings outside
MDM scope.
Scripts are uploaded via the Jamf portal, attached to policies, and run with customizable
triggers.
Automated app deployment using App Store, VPP, or custom packages in cloud distribution points.
Patch management keeps OS and critical apps up to date across your fleet, using policies and dashboards.
Self Service Portal
A branded app for users to self-install approved apps, run support scripts, or access help resources.
Reduces IT workload by empowering end-users for common tasks.
Inventory Collection & Reporting
Regular, automated submission of hardware/software inventory and extension attribute data.
Use advanced reporting and search functions, with smart groups as filters, for compliance and lifecycle management.
Enforce security baselines via configuration profiles and policies (FileVault, Gatekeeper, password rules).
Monitor compliance with smart groups and automate remediation or send alerts for non-compliant devices.
APIs for workflow and data automation connect with ITSM, ticketing, SIEM, and identity systems (e.g., Entra ID, Okta).
Directory integrations sync users/groups for policy and Self Service assignment.
Use cloud storage (S3, Azure Blob) for global package/app hosting.
Real-World Jamf Pro Cloud Workflows
Device Enrollment (Zero-Touch)
1. Purchase devices and assign them to Jamf in Apple Business Manager.
2. The user opens the device, which contacts Apple and redirects to Jamf Pro Cloud for automatic enrollment.
3. Initial configurations, apps, and policies are automatically applied.
4. Devices are secured and managed without IT intervention at each site.
Deploying an App Remotely
1. Admin uploads an app package or selects an App Store item in Jamf Pro portal.
2. Creates a deployment policy and scopes it using a Smart Group.
3. Policy triggers on next device check-in and app installs remotely or via Self Service.
Enforcing Security Compliance
1. Create a FileVault required configuration profile.
2. Scope to a Smart Group with criteria for devices lacking FileVault encryption.
3. Profile applies on next check-in, enabling FileVault or prompting action.
4. Smart Group and dashboard highlight non-compliant devices for follow-up.
Best Practices & Tips
Use Smart Groups for compliance and automated remediation.
Pilot new policies/scripts on a small Static Group before broad deployment.
Name policies, profiles, and groups clearly for ease of management.
Balance check-in and inventory frequencies to avoid overloading networks.
Leverage Self Service to decentralize app/support delivery and empower end users.
Integrate SSO/Directory services for secure, role-based admin and user access.
Regularly review reports, dashboards, and group memberships for ongoing compliance and resource optimization.
Stay current on Jamf Cloud update, release notes.
Thank you so much ​@JoannaB  for publishing the blog!!
of course! thank you for your work!
