Lock Screen Message - Variables
  • January 12, 2017
  • 5 replies
  • 151 views
Is it possible to put in variables within these fields such as the serial number of a device easily? This would be very handy to be able to see on the lock screen.
Thanks. :)
mscottblake
  • January 12, 2017
Here is a list of variables that can be used in a Mobile Device Configuration Profile.
  • January 12, 2017
Thank you!
chrisgrande
  • January 26, 2017
FYI, these variables aren't dynamic once on device, so if you use #DEVICENAME it burns that name onto Home Screen and it doesn't update if the device name changes. You need to remove and reapply the config to get the new name.
  • November 30, 2017
@cgrande thanks for the heads up on this. I noticed that when I automatically enrolled a device through configurator and then later paired a user with the device, the Lock Screen Message was impartial (only showed part of the script). When I excluded the device from the configuration profile and then added it again, the lock screen message stated everything I needed it to. Thanks!
  • July 16, 2023
I just tryed it with $USERNAME, its not working. Thar variable is shown on the lock screen. It doesnt mater if i use $ (as in documentation) or # (your example) ...
