Creating a local admin at enrolment to get a secure token?
  • August 9, 2018
  • 5 views
Hey all,
If i create a local admin at prestage enrolment, when that user logs in, do they create a secure token that can be used in 10.13.4 + ?
Thanks !
1 reply
  • August 9, 2018
I have a local admin user created in my prestage enrollment workflow.
Yes, the user created is issued a SecureToken. Which will then allow you to enable SecureToken for other users
