Pairing via Mac? Create a new pre-stage enrollment for that one ipad. Can also exclude the restrictions profile from the device so it can be paired with non configurator hosts. This doesnt solve the 'specific computer' part though.
So I've tried re-enrolling under a new pre-stage for this while leaving "Allow Devices to connect..." un-checked and made sure it was unchecked in the config profile under restrictions. When trying to connect to the machine that configured this particular iPad, I get the "This iPad is supervised by another computer and cannot be used with this computer" message.
Seems like this may not be possible...
The one saving grace in this is that once I re-enable pairing, you need to enter the iPad passcode to "Trust" the computer you are connecting to. So if the authorized user is responsible, it isn't a problem.
I would restore it in DFU mode and then try.
If you allow pairing in the Pre-Stage Enrollment you can then restrict it via a configuration profile. Then, when pairing is needed, you can exclude the device from the config profile to let them access the videos. When they're done, you can re-restrict by removing the exclusion. That's what we do in our K-12 environment, hope it helps :)
If "Allow Pairing" was disabled when an iPad was set up is there a way to remove the restriction without restoring the device?
Check your Pre-Stage Enrollment - if Pairing is not checked there, you will have to wipe and re-enroll once that box is checked. Then you can restrict pairing with a configuration profile.
