Just wanted to check something before I continue:
I'm currently working on a migration from a production Casper 9.91 environment running on a Server 2012 R2 machine to Jamf Pro 9.98 running on Server 2016. I'm unable to restore the backup that I created on the old server (It hangs in the initialisation process @ the webinterface) and I've decided to start fresh with a new DB since there isn't really a lot of data that needs to be moved. I already did a repair after I've imported the backup but that didn't helped btw.
I'm now at the stage of importing my MDM certificate that I currently use in the production JSS and configuring it at my new JSS and I was wondering If I can safely do this without breaking my current running environment.
The idea is to mirror everything to the new JSS (Packages, policies etc.), import my MDM certficate (without breaking the current certificate on the clients/production JSS) and change the DNS entry to the new server so that the clients check-in in my new Setup and I can safely remove the old one.
Is this going to work?
Looking forward to hear something soon :).
