Extension attribute for Chrome only works in terminal
  • June 13, 2019
  • 23 views
beeboo
So the name of the chrome extension is is listed below and running this script in terminal brings forth no issues, but running the script in EA does.
i ran a recon - verbose and it throws and error into the TMP file
!bin/bash
Pulls the current logged in user
currentUser=$(stat -f%Su /dev/console)
if [[ -e "/Users/"$currentUser"/Library/Application Support/Google/Chrome/Default/Extensions/fckonodhlfjlkndmedanenhgdnbopbmh" ]];
then echo "<result>Installed</result>"
else echo "<result>NOT Installed</result>"
donmontalvo
Forum|alt.badge.img+36
  • June 14, 2019
Have you tried Italic? :)
#Pulls the current logged in user
currentUser=$( python -c 'from SystemConfiguration import SCDynamicStoreCopyConsoleUser; import sys; username = (SCDynamicStoreCopyConsoleUser(None, None, None) or [None])[0]; username = [username,""][username in [u"loginwindow", None, u""]]; sys.stdout.write(username + "
if [ -e "/Users/"$currentUser"/Library/Application Support/Google/Chrome/Default/Extensions/fckonodhlfjlkndmedanenhgdnbopbmh" ];
then
beeboo
  • June 18, 2019
so i tried a slightly modified version
walkMeVersion=$(ls -d "/Users/"$currentUser"/Library/Application Support/Google/Chrome/Default/Extensions/fckonodhlfjlkndmedanenhgdnbopbmh/"* | cut -f11 -d '/')
echo "<result>"Testing: $walkMeVersion"</result>"
that works in shell to pull up version but wont display in EA as im trying to make a smart group from the EA
