Policy with Login or Recurring Checking not Installing Software Properly
  • March 22, 2018
  • 4 replies
  • 8 views
I've been having some issues with Policies not installing certain software in the background properly. The application will not open and throws an error. However, the software is installed properly if I use Self Service. The logs look identical.
From the Policy at Recurring Checkin
Mar 22 10:24:04 iMac-IP-Desk installer[5579]: Product archive /Library/Application Support/JAMF/Downloads/Install Pro Tools 2018.3.0.pkg trustLevel=100
Mar 22 10:24:21 iMac-IP-Desk installd[992]: PackageKit: Touched bundle /Applications/Pro Tools.app
Mar 22 10:24:21 iMac-IP-Desk installd[992]: PackageKit: Touched bundle /Applications/Pro Tools.app/Contents/Frameworks/Chromium Embedded Framework.framework/Versions/A/Resources/crash_report_sender.app
Mar 22 10:24:21 iMac-IP-Desk installd[992]: PackageKit: Touched bundle /Applications/Pro Tools.app/Contents/Frameworks/Crash Reporter.app
Mar 22 10:24:21 iMac-IP-Desk installd[992]: PackageKit: Touched bundle /Applications/Pro Tools.app/Contents/Frameworks/Pro Tools Helper EH.app
Mar 22 10:24:21 iMac-IP-Desk installd[992]: PackageKit: Touched bundle /Applications/Pro Tools.app/Contents/Frameworks/Pro Tools Helper NP.app
Mar 22 10:24:21 iMac-IP-Desk installd[992]: PackageKit: Touched bundle /Applications/Pro Tools.app/Contents/Frameworks/Pro Tools Helper.app
Mar 22 10:24:21 iMac-IP-Desk installd[992]: PackageKit: Touched bundle /Applications/Pro Tools.app/Contents/Frameworks/Video Engine/AvidVideoEngine.app
Mar 22 10:24:21 iMac-IP-Desk installd[992]: PackageKit: Touched bundle /Applications/Pro Tools.app/Contents/Frameworks/Video Engine/AvidVideoEngine.app/Contents/QuickTimeServer/QuickTime_OPServer.app
Mar 22 10:24:21 iMac-IP-Desk installd[992]: PackageKit: Touched bundle /Applications/Pro Tools.app/Contents/QuickTimeServer/Pro Tools QuickTime Server.app
From the Policy via Self Service
Mar 22 10:52:36 iMac-IP-Desk installd[921]: PackageKit: Touched bundle /Applications/Pro Tools.app
Mar 22 10:52:36 iMac-IP-Desk installd[921]: PackageKit: Touched bundle /Applications/Pro Tools.app/Contents/Frameworks/Chromium Embedded Framework.framework/Versions/A/Resources/crash_report_sender.app
Mar 22 10:52:36 iMac-IP-Desk installd[921]: PackageKit: Touched bundle /Applications/Pro Tools.app/Contents/Frameworks/Crash Reporter.app
Mar 22 10:52:36 iMac-IP-Desk installd[921]: PackageKit: Touched bundle /Applications/Pro Tools.app/Contents/Frameworks/Pro Tools Helper EH.app
Mar 22 10:52:36 iMac-IP-Desk installd[921]: PackageKit: Touched bundle /Applications/Pro Tools.app/Contents/Frameworks/Pro Tools Helper NP.app
Mar 22 10:52:36 iMac-IP-Desk installd[921]: PackageKit: Touched bundle /Applications/Pro Tools.app/Contents/Frameworks/Pro Tools Helper.app
Mar 22 10:52:36 iMac-IP-Desk installd[921]: PackageKit: Touched bundle /Applications/Pro Tools.app/Contents/Frameworks/Video Engine/AvidVideoEngine.app
Mar 22 10:52:36 iMac-IP-Desk installd[921]: PackageKit: Touched bundle /Applications/Pro Tools.app/Contents/Frameworks/Video Engine/AvidVideoEngine.app/Contents/QuickTimeServer/QuickTime_OPServer.app
Mar 22 10:52:36 iMac-IP-Desk installd[921]: PackageKit: Touched bundle /Applications/Pro Tools.app/Contents/QuickTimeServer/Pro Tools QuickTime Server.app
Has anyone else had this issue?
  • 253 replies
  • March 22, 2018
I am preparing our apps for deployment. I just tested the ProTools deployment and don't see anything strange.
  • 10 replies
  • March 22, 2018
How did you build your package? I ran the pkg through Composer and rebuilt it as that's what I've read from past users. Only works from Self Service for some reason.
  • 253 replies
  • March 23, 2018
@ivanpiesh I copied the installer into Composer, I then put the iLock installer into the Policy.
I then run the script:
Copy the com.avid.bsd.ShoeTool Helper Tool
PHT_SHOETOOL="/Library/PrivilegedHelperTools/com.avid.bsd.shoetoolv120" /bin/cp -f "/Applications/Pro Tools.app/Contents/Library/LaunchServices/com.avid.bsd.shoetoolv120" $PHT_SHOETOOL /usr/sbin/chown root:wheel $PHT_SHOETOOL /bin/chmod 544 $PHT_SHOETOOL
Create the Launch Deamon Plist for com.avid.bsd.ShoeTool
PLIST="/Library/LaunchDaemons/com.avid.bsd.shoetoolv120.plist" FULL_PATH="/Library/PrivilegedHelperTools/com.avid.bsd.shoetoolv120" rm $PLIST # Make sure we are idempotent /usr/libexec/PlistBuddy -c "Add Label string" $PLIST /usr/libexec/PlistBuddy -c "Set Label com.avid.bsd.shoetoolv120" $PLIST /usr/libexec/PlistBuddy -c "Add MachServices dict" $PLIST /usr/libexec/PlistBuddy -c "Add MachServices:com.avid.bsd.shoetoolv120 bool" $PLIST /usr/libexec/PlistBuddy -c "Set MachServices:com.avid.bsd.shoetoolv120 true" $PLIST /usr/libexec/PlistBuddy -c "Add ProgramArguments array" $PLIST /usr/libexec/PlistBuddy -c "Add ProgramArguments:0 string" $PLIST /usr/libexec/PlistBuddy -c "Set ProgramArguments:0 $FULL_PATH" $PLIST /bin/launchctl load $PLIST mkdir -p "/Library/Application Support/Avid/Audio/Plug-Ins" mkdir -p "/Library/Application Support/Avid/Audio/Plug-Ins (Unused)" chmod a+w "/Library/Application Support/Avid/Audio/Plug-Ins" chmod a+w "/Library/Application Support/Avid/Audio/Plug-Ins (Unused)" mkdir /Users/Shared/Pro Tools mkdir /Users/Shared/AvidVideoEngine chown -R root:wheel /Users/Shared/Pro Tools chmod -R a+rw /Users/Shared/Pro Tools chown -R root:wheel /Users/Shared/AvidVideoEngine chmod -R a+rw /Users/Shared/AvidVideoEngine
Get rid of old workspace
rm -rf /Users/Shared/Pro Tools/Workspace.wksp exit 0
Force a reboot. Done
[https://www.jamf.com/jamf-nation/discussions/17288/pro-tools-12](link URL)
  • 10 replies
  • July 21, 2021
Thank you for this. I'll try this out. Cheers.
