I'm trying out imaging High Sierra as HFS+ to get around the lack of APFS support in existing imaging tools. The issue I am running into with Casper Imaging 9.101 is that, at first reboot, the system sits at the login screen with instead of running cached installers and scripts. I can select the adobeinstall account, but of course it wants a password.
I haven't heard of this issue yet. Is it a known problem, or is there any fix?
