Has anyone been able to successfully deploy SugarSync? The installer available on their website is a .app wrapped in a DMG. It appears as though this installer app is exactly the same (size-wise anyway) as what ends up in the /Applications folder. The install process seems to be that it simply copies itself into the /Applications folder and then runs in some install mode as opposed to a normal run mode. It adds some stuff in /Library, as well as installs OSXFuse. I haven't figured out how it determines whether to be in install mode or run mode.
I've tried snapshotting it with Composer, but this does not produce a working copy. I've also tried investigating for switches to the .app and had no luck there. I emailed their tech support asking about administrative deployment options and was told "At this time, SugarSync does not have a feature in place to mass install onto multiple computers. This is a feature request we are aware of and making strides to provide this to our business customers, however, there is not expected release date." Grrrr...
Ultimately I'm trying to make SugarSync available as a SelfService install. Any help is appreciated.
Thanks,
Eric
