Password Policy JMAF Pro
  • June 21, 2019
  • 73 views
Hello Team,
We created a passcode policy and deployed around 75 macs to our business unit, but we have some problem in this the password has changed after rebooting the password it doesn't work. We've enabled FileVault.
Password has changed successfully and works on the policy. Sometimes FileVault accepts the password after it asks username & password again
We don't have AD server we were using for Jamf pro password policy configuration profile
If any have an idea, please
Best answer by Senthil_kumar
Hi Dawid,
I got the solution from Jamf support, now I'm using a script to remove the configuration profile. And now deploy to the script perfectly working fine. i have to modify something
Below is the script
!/bin/bash
Password Policy Settings #
MAX_FAILED=5 # 5 max failed logins before locking
LOCKOUT=60 # 1min lockout
PW_EXPIRE=90 # 90 days password expiration
MIN_LENGTH=8 # at least 8 chars for password
MIN_NUMERIC=1 # at least 1 number in password
MIN_ALPHA_LOWER=1 # at least 1 lower case letter in password
MIN_UPPER_ALPHA=1 # at least 1 upper case letter in password
MIN_SPECIAL_CHAR=1 # at least 1 special character in password
PW_HISTORY=10 # remember last 10 passwords
exemptAccount1="Admin account" #Exempt account used for remote management. CHANGE THIS TO YOUR EXEMPT ACCOUNT
if [ $PW_EXPIRE -lt "1" ];
then echo "PW EXPIRE TIME CAN NOT BE 0 or less." exit 1
for user in $(dscl . list /Users UniqueID | awk '$2 >= 500 {print $1}'); do if [ "$user" != "$exemptAccount1" ]; then
#Check if current plist is installed by comparing the current variables to the new ones
#PW_History currentPwHistory=$(sudo pwpolicy -u "$user" -getaccountpolicies | grep "<string>Does not match any of last $PW_HISTORY passwords</string>" | sed -e 's/^[[:space:]]//' -e 's/[[:space:]]$//' ) newPwHistory="<string>Does not match any of last $PW_HISTORY passwords</string>"
#MIN_SPECIAL_CHAR currentMinSpecialChar=$(sudo pwpolicy -u "$user" -getaccountpolicies | grep "<string>policyAttributePassword matches '(.[^a-zA-Z0-9].){$MIN_SPECIAL_CHAR,}'</string>" | sed -e 's/^[[:space:]]//' -e 's/[[:space:]]$//' ) newMinSpecialChar="<string>policyAttributePassword matches '(.[^a-zA-Z0-9].){$MIN_SPECIAL_CHAR,}'</string>"
#MIN_UPPER_ALPHA currentUpperLimit=$(sudo pwpolicy -u "$user" -getaccountpolicies | grep "<string>policyAttributePassword matches '(.[A-Z].){$MIN_UPPER_ALPHA,}'</string>" | sed -e 's/^[[:space:]]//' -e 's/[[:space:]]$//' ) newUpperLimit="<string>policyAttributePassword matches '(.[A-Z].){$MIN_UPPER_ALPHA,}'</string>"
#MIN_ALPHA_LOWER currentLowerLimit=$(sudo pwpolicy -u "$user" -getaccountpolicies | grep "<string>policyAttributePassword matches '(.[a-z].){$MIN_ALPHA_LOWER,}'</string>" | sed -e 's/^[[:space:]]//' -e 's/[[:space:]]$//' ) newLowerLimit="<string>policyAttributePassword matches '(.[a-z].){$MIN_ALPHA_LOWER,}'</string>"
#MIN_NUMERIC currentNumLimit=$(sudo pwpolicy -u "$user" -getaccountpolicies | grep "<string>policyAttributePassword matches '(.[0-9].){$MIN_NUMERIC,}'</string>" | sed -e 's/^[[:space:]]//' -e 's/[[:space:]]$//' ) newNumLimit="<string>policyAttributePassword matches '(.[0-9].){$MIN_NUMERIC,}'</string>"
#MIN_LENGTH currentMinLength=$(sudo pwpolicy -u "$user" -getaccountpolicies | grep "<string>policyAttributePassword matches '.{$MIN_LENGTH,}'</string>" | sed -e 's/^[[:space:]]//' -e 's/[[:space:]]$//' ) newMinLength="<string>policyAttributePassword matches '.{$MIN_LENGTH,}'</string>"
#PW_EXPIRE currentPwExpire=$(sudo pwpolicy -u "$user" -getaccountpolicies | grep "<string>Change every $PW_EXPIRE days</string>" | sed -e 's/^[[:space:]]//' -e 's/[[:space:]]$//' ) newPwExpire="<string>Change every $PW_EXPIRE days</string>"
#LOCKOUT currentLockOut=$(sudo pwpolicy -u "$user" -getaccountpolicies | grep "<integer>$LOCKOUT</integer>" | sed -e 's/^[[:space:]]//' -e 's/[[:space:]]$//' ) newLockOut="<integer>$LOCKOUT</integer>"
#MAX_FAILED currentMaxFailed=$(sudo pwpolicy -u "$user" -getaccountpolicies | grep "<integer>$MAX_FAILED</integer>" | sed -e 's/^[[:space:]]//' -e 's/[[:space:]]$//' ) newMaxFailed="<integer>$MAX_FAILED</integer>"
isPlistNew=0
if [ "$currentPwHistory" == "$newPwHistory" ]; then echo "PW_HISTORY is the same" else echo "PW_HISTORY is NOT the same" echo "current: $currentPwHistory" echo "new: $newPwHistory" isPlistNew=1 fi
if [ "$currentMinSpecialChar" == "$newMinSpecialChar" ]; then echo "MIN_SPECIAL_CHAR is the same" else echo "MIN_SPECIAL_CHAR is NOT the same" echo "current: $currentMinSpecialChar" echo "new: $newMinSpecialChar" isPlistNew=1 fi
if [ "$currentUpperLimit" == "$newUpperLimit" ]; then echo "MIN_UPPER_ALPHA is the same" else echo "MIN_UPPER_ALPHA is NOT the same" echo "current: $currentUpperLimit" echo "new: $newUpperLimit" isPlistNew=1 fi
if [ "$currentLowerLimit" == "$newLowerLimit" ]; then echo "MIN_ALPHA_LOWER is the same" else echo "MIN_ALPHA_LOWER is NOT the same" echo "current: $currentLowerLimit" echo "new: $newLowerLimit" isPlistNew=1 fi
if [ "$currentNumLimit" == "$newNumLimit" ]; then echo "MIN_NUMERIC is the same" else echo "MIN_NUMERIC is NOT the same" echo "current: $currentNumLimit" echo "new: $newNumLimit" isPlistNew=1 fi
if [ "$currentMinLength" == "$newMinLength" ]; then echo "MIN_LENGTH is the same" else echo "MIN_LENGTH is NOT the same" echo "current: $currentMinLength" echo "new: $newMinLength" isPlistNew=1 fi
if [ "$currentPwExpire" == "$newPwExpire" ]; then echo "PW_Expire is the same" else echo "PW_Expire is NOT the same" echo "current: $currentPwExpire" echo "new: $newPwExpire" isPlistNew=1 fi
if [ "$currentLockOut" == "$newLockOut" ]; then echo "LOCKOUT is the same" else echo "LOCKOUT is NOT the same" echo "current: $currentLockOut" echo "new: $newLockOut" isPlistNew=1 fi
if [ "$currentMaxFailed" == "$newMaxFailed" ]; then echo "MAX_FAILED is the same" else echo "MAX_FAILED is NOT the same" echo "current: $currentMaxFailed" echo "new: $newMaxFailed" isPlistNew=1 fi
if [ "$isPlistNew" -eq "1" ]; then
# Creates plist using variables above echo "<dict> <key>policyCategoryAuthentication</key> <array> <dict> <key>policyContent</key> <string>(policyAttributeFailedAuthentications &lt; policyAttributeMaximumFailedAuthentications) OR (policyAttributeCurrentTime &gt; (policyAttributeLastFailedAuthenticationTime + autoEnableInSeconds))</string> <key>policyIdentifier</key> <string>Authentication Lockout</string> <key>policyParameters</key> <dict> <key>autoEnableInSeconds</key> <integer>$LOCKOUT</integer> <key>policyAttributeMaximumFailedAuthentications</key> <integer>$MAX_FAILED</integer> </dict> </dict> </array>
<key>policyCategoryPasswordChange</key> <array> <dict> <key>policyContent</key> <string>policyAttributeCurrentTime &gt; policyAttributeLastPasswordChangeTime + (policyAttributeExpiresEveryNDays 24 60 * 60)</string> <key>policyIdentifier</key> <string>Change every $PW_EXPIRE days</string> <key>policyParameters</key> <dict> <key>policyAttributeExpiresEveryNDays</key> <integer>$PW_EXPIRE</integer> </dict> </dict> </array>
<key>policyCategoryPasswordContent</key> <array> <dict> <key>policyContent</key> <string>policyAttributePassword matches '.{$MIN_LENGTH,}+'</string> <key>policyIdentifier</key> <string>Has at least $MIN_LENGTH characters</string> <key>policyParameters</key> <dict> <key>minimumLength</key> <integer>$MIN_LENGTH</integer> </dict> </dict>
<dict> <key>policyContent</key> <string>policyAttributePassword matches '(.[0-9].){$MIN_NUMERIC,}+'</string> <key>policyIdentifier</key> <string>Has a number</string> <key>policyParameters</key> <dict> <key>minimumNumericCharacters</key> <integer>$MIN_NUMERIC</integer> </dict> </dict>
<dict> <key>policyContent</key> <string>policyAttributePassword matches '(.[a-z].){$MIN_ALPHA_LOWER,}+'</string> <key>policyIdentifier</key> <string>Has a lower case letter</string> <key>policyParameters</key> <dict> <key>minimumAlphaCharactersLowerCase</key> <integer>$MIN_ALPHA_LOWER</integer> </dict> </dict>
<dict> <key>policyContent</key> <string>policyAttributePassword matches '(.[A-Z].){$MIN_UPPER_ALPHA,}+'</string> <key>policyIdentifier</key> <string>Has an upper case letter</string> <key>policyParameters</key> <dict> <key>minimumAlphaCharacters</key> <integer>$MIN_UPPER_ALPHA</integer> </dict> </dict>
<dict> <key>policyContent</key> <string>policyAttributePassword matches '(.[^a-zA-Z0-9].){$MIN_SPECIAL_CHAR,}+'</string> <key>policyIdentifier</key> <string>Has a special character</string> <key>policyParameters</key> <dict> <key>minimumSymbols</key> <integer>$MIN_SPECIAL_CHAR</integer> </dict> </dict>
<dict> <key>policyContent</key> <string>none policyAttributePasswordHashes in policyAttributePasswordHistory</string> <key>policyIdentifier</key> <string>Does not match any of last $PW_HISTORY passwords</string> <key>policyParameters</key> <dict> <key>policyAttributePasswordHistoryDepth</key> <integer>$PW_HISTORY</integer> </dict> </dict>
</array> </dict>" > /private/var/tmp/pwpolicy.plist #save the plist temp
chmod 777 /private/var/tmp/pwpolicy.plist
pwpolicy -u "$user" -clearaccountpolicies pwpolicy -u "$user" -setaccountpolicies /private/var/tmp/pwpolicy.plist fi fi
done
rm /private/var/tmp/pwpolicy.plist
echo "Password policy successfully applied. Run "sudo pwpolicy -u <user> -getaccountpolicies" to see it."
  • September 19, 2019
Hi skumar8,
I am currently running into the same issues, did you managed to find any solution yet?
After applying a password policy to 4 test devices 2 of them locked out completely and they were not taking any passwords. Ever resetting the password using a FileVault key only updated the password for FileVault but left the account password 'broken'. Best
Dawid
  • January 24, 2020
Hi Dawid,
Below is the script
!/bin/bash
isPlistNew=0
done
