Huge improvements...if you're usint RDP, you're gonna want to jump on this...
Nice! I Like it!
Very nice! I like the look and feel of it.
Still doesn't support dual monitor support corrretly while in full screen.
I don't need it taking up both monitors...just one...with my mac on the other.
Jump on the Beta and post to their forum, they are very responsive.
@ooshnoo I have a dual monitor setup and I have it full screen on one monitor with my Mac on the other. Is this not working for you? The RDP session will go full screen on whichever monitor the RDP app is currently focused on. I drag it to the monitor on my right so I have windows full screen on that monitor and leave my left monitor full screen in OS X.
Here are how I have my settings configured.
that looks to be the screenshot from the current release version available on the AppStore, which works just fine with dual monitors. We're talking about RDC beta.
@donmontalvo are you referring to the user voice forums?
8.2.30 hot off the press...
What's new in this update: *Redesigned multi monitor experience
Has anyone noticed not being able to change the font size when using the Microsoft Remote Beta on Mac OS by chance? If so, have you found a fix?
