I've been reading how to deploy printers via the command line and with the great advice of mpermann in answering others questions. I think I have a OK handle on it...
But i'm stuck at one thing, The Finisher for Ricoh Printers. The first time I send the command:
l[padmin -p lpr139c -E -v lpd://172.29.134.121 -m /Library/Printers/PPDs/Contents/Resources/RICOH Aficio MP 4002.gz -o printer-is-shared=false -o Finisher=FinKINGB
Printer gets added on the client machine, but the Finisher is 'Not Installed' If I send it a second time, the Finisher gets properly set.
Not sure why I have to run it a second time to get the finisher to set... Should I be running it one to just install, and a second command after to set the Finisher? Anyone seen this before?
On a side note, what is the "tag" I use to get the command above to appear as a single long line that you scroll across? instead of it auto-wrapping in the post box?
