Pages, Keynote, Numbers v3.0 requires iOS 10 (JSS sending app update command to iOS 9.x devices)
  • September 14, 2016
  • 0 replies
  • 11 views
Anyone seeing the JSS sending out the install command for the new iWork app 3.0 updates to iOS 9.x devices? I noticed that these devices are having those apps reinstalled today and we are getting a bunch of Failed commands in the order of: The app with iTunes Store ID 361309726 is already scheduled for management on Pages for example.
Just FYI if you have Automatic App updates turned on, it appears you might get unnecessary bandwidth usage until your devices are on iOS 10.
