All,
Another oddity. Many of my machines now show duplicate entries of some packages in the imaging plan (left side bar) of the imagining window. For example, the plan says:
OS 10.5.8 base.dmg
Adobe Acrobat.dmg
Adobe Acrobat.dmg
Adobe Acrobat.dmg
Adobe Acrobat.dmg
Alice.dmg
BlueJ.dmg
BlueJ.dmg
BlueJ.dmg
BlueJ.dmg
etc.
Most of the packages appear normally (once), and this doesn't occur on all the machines. Thinking back, these are packages that I pushed out by hand (using casper remote) to some machines. Did I inadvertently check or uncheck something? The configuration in CasperAdmin appears normal. How to fix?
-Baker
Baker Franke
Computer Science Dept.
University of Chicago Laboratory Schools
773.702.5419
Have you by chance jumped between custom config and easy config within
Casper Imaging? =)
I've seen some strange things there, but hadn't put a finger on it.
Craig E
