Novice scripter trying to modify a script from github to delete all empty usergroups from Jamf.
Currently getting line 26: syntax error near u'expected token `do
Eventually I want this script to also delete empty classes as well.
# Script to delete empty usergroups
jssUser="******" # Full JSS Admin Account
jssPass="******" # Password for the JSS Admin Account
index="0"
usergroups=()
echo $jssURL
IDs=`curl -sk -u $jssUser:$jssPass -H "Accept: text/xml" "https://******.jamfcloud.com/JSSResource/usergroups" -X GET`
size=`echo $IDs | xpath //user_groups/size | sed 's/<[^>]*>//g'`
echo $size " user groups will be scanned."
#Put the IDs into an array
while [ $index -lt ${size} ]
do
index=$[$index+1]
usergroups+=(`echo $IDs | xpath //user_groups/user_group[${index}]/id | sed 's/<[^>]*>//g'`)
done
# Sort through each user ID individually and grep for IDs size
for i in "${usergroups[@]}"
do
usergroup=`curl -sk -u $jssUser:$jssPass -H "Accept: text/xml" "https://******.jamfcloud.com/JSSResource/usergroups/id/${i}" -X GET`
groupsize=`echo $usergroup | xpath //user_group/users/size | grep id`
# Delete users that meet our criteria
if [[$groupsize -eq 0]] ; then
echo "Deleting ${i}"
curl -k -v -u $jssUser:$jssPass -H "Accept: text/xml" "https://******.jamfcloud.com/JSSResource/usergroups/id/${i}" -X DELETE
done
Are you missing a second done to close off the if statements? I'd give that a go!
@MDMMan When posting scripts to Jamf Nation, please use leading and trailing triple backticks (```) to signify a code block.
As a handy tool for checking scripts, take a look at ShellCheck. It gives you interactive feedback on your script, so you could quickly try @connor's suggestion to see if that eliminated the syntax error.
@connor I have two DOs and two DONEs. I have one IF and one FI.
@sdagley Thanks for the backticks tip. It definitely makes the code block more readable.
ShellCheck says what Connor said. I tried adding another done but it didn't make a difference. ShellCheck doesn't seem to be able to read the done for either do.
It also doesn't like the While statement.
@MDMMan You need a space after the [[ and before the ]] on line 31 in the script as it currently reads above. Once you do that ShellCheck will have several additional suggestions.
Thanks. I have reworked the script based on shellcheck. Still getting errors. line 22: syntax error near unexpected token `do
It wants me to add additional double quotes that do not appear to be needed..
jssUser="****" # Full JSS Admin Account
jssPass="****" # Password for the JSS Admin Account
index="0"
usergroups=()
IDs=$(curl -sk -u $jssUser:$jssPass -H "Accept: text/xml" "https://****.jamfcloud.com/JSSResource/usergroups" -X GET)
size=$(echo $IDs | xpath //user_groups/size | sed 's/<[^>]*>//g')
while [ $index -lt $size ]
do
index=$($index+1)
usergroups+=( "$(echo "$IDs | xpath //user_groups/user_group[${index}]/id | sed 's/<[^>]*>//g')")" )
echo $usergroups >>"/tmp/usergroups.txt"
done
do
usergroup=$(curl -sk -u $jssUser:$jssPass -H "Accept: text/xml" "https://****.jamfcloud.com/JSSResource/usergroups/id/${i}" -X GET)
groupsize="$(echo "$usergroup | xpath //user_group/users/size | grep id")"
if [[ $groupsize -eq 0 ]] ; then
curl -k -v -u $jssUser:$jssPass -H "Accept: text/xml" "https://****.jamfcloud.com/JSSResource/usergroups/id/${i}" -X DELETE
done
@MDMMan ShellCheck isn't showing a syntax error for the most recent version of the script you've posted. What did you change from the version you're trying to run?
Here is the current version that is still returning the syntax error when running the script via terminal.
jssPass="*****" # Password for the JSS Admin Account
index="0"
usergroups=()
do
index=$($index+1)
usergroups+=( "$IDs | xpath //user_groups/user_group[${index}]/id | sed 's/<[^>]*>//g')" )
done
do
usergroup=$(curl -sk -u $jssUser:$jssPass -H "Accept: text/xml" "https://*****.jamfcloud.com/JSSResource/usergroups/id/${i}" -X GET)
groupsize="$usergroup | xpath //user_group/users/size | grep id"
done
