Bitlocker to go - does exist something similar on Mac?
  • June 26, 2015
  • 6 replies
  • 25 views
Hello everybody,
I've been asked whether is possible to replicate the functionality of BitLocker To Go on Mac.
Does anybody has already dealt with this request?
Thanks to all.
Regards,
Jacopo
davidacland
  • June 26, 2015
Hi @Jachk
If I am reading it right, Bitlocker to Go lets you encrypt external and removable drives.
You can do this natively in OS X if you right-click on the drive and select "Encrypt"
  • June 26, 2015
Hi @davidacland ,
yes, you're right.
At the moment, when I insert a USB stick on Win, BitLocker ToGo forces me to encrypt the USB stick if I want to write on it. Otherwise it lets me only read.
On Mac I know I can right click on the USB drive and then encrypt it. It doesn't prompt me anything.
I'd like to implement a similar solution also on Mac platform. Maybe I can manage it using a script and cocoadialog...
davidacland
  • June 26, 2015
To enforce that behaviour you can use something like Endpoint Protector.
  • June 26, 2015
Thanks for the advice,
I'll definitely give it a try.
  • November 20, 2019
Has anyone used M3 Bitlocker Loader for Mac
https://www.m3datarecovery.com/mac-bitlocker/
Or
Hasleo BitLocker Anywhere For Mac
https://www.easyuefi.com/bitlocker-for-mac/bitlocker-for-mac.html
  • November 21, 2019
We use M3 Bitlocker Loader. It can be a bit finicky, especially on Catalina, but it works for the most part
