- Home
- Community
- Get Support
- General Discussions
- Can't launch any Apple apps as a certain user - sandbox error
- September 16, 2016
- 22 replies
- 172 views
- New Contributor
- September 20, 2016
Hi Eric,
I've seen exactly the same problem as you have, and am also struggling to find both a root cause and a fix for this (other than completely wiping and rebuilding the Mac). I've seen the error on 3 different Macs where I work : always for a certain user account - unable to open any app that uses the sandbox, and Safari doesn't load any pages. Exact same error as you in the crash report:
Sandbox creation failed: failed to compile sandbox profile
invalid data type of path filter; expected string, got Boolean
I'm also trying to see if this error is being caused by a 3rd party app - do you by any chance use the Forescout SecureConnector (network security software) on your Macs ?
Thanks
Jamie
- Author
- Contributor
@JamieMacJ No, I don't have that software, but I'm curious if it's a third party app causing my issues as well. This is the only system on our campus where we allow the end users admin rights, so obviously that lends itself to thinking "what did they do"?
I ended up reimaging the computer, as we needed to make it operational again, and have asked that they provide me information on all software before they install it.
If the issue pops up again and I figure out a fix, I'll let you know.
Eric
- Contributor
This line is interesting...
invalid data type of path filter; expected string, got boolean
Are these normal home directories? If you dscl the user, what is the NFSHomeDirectory path?
dscl . -read /Users/usernamehere NFSHomeDirectory- Author
- Contributor
@thoule Yes, normal home directories, /Users/username. It's a mobile account, but there's no syncing or anything like that.
I was trying to figure out what that line meant as well. It had me thinking plist, but I never got any further.
- Contributor
No idea.. It can't make the sandbox profile. That's usually in /Users/username/Containers directory. You get a replica of your Library with no contents so that app acts like it's all alone. This keeps the app isolated for security and stability. You can look at your /Users/username/Library/Containers directory and see if the permissions are borked on anything in there. You could also try trashing the specific sandbox for the problematic application (you'll loose prefs and data for that app).
As for the error message, It's trying to get a filter for the path to that sandbox. No idea what filter it's looking for. It wanted to get a string (a line of text), but got a Yes/No answer instead and crashed saying 'now I'm confused'.
- Author
- Contributor
@thoule Yeah, that's pretty much what I had read into the error as well. And I've already investigated for problems in the ~/Library/Containers directory, including trashing the prefs for a specific app (though the fact that it's all sandboxed apps leads me to think there's a bigger issue) and deleting the home folder entirely and allowing a new one to be created. I think I also tried copying (and correcting permissions) the Containers folder from the home directory of a user that wasn't having this problem, but didn't have any luck.
Also, now that I've reimaged the computer, I restored the user home folder as it was prior to reimage and everything is still working fine. So it seems unlikely the issue is related to anything in the home folder. I wondered if something could have gotten corrupted in /System/Library/Sandbox, but with SIP protecting those files, it would be difficult for anything to get messed up in there, or to troubleshoot it.
Thanks for the ideas.
Eric
- New Contributor
- October 3, 2016
@thoule curious I've been seeing this a bit as well lately. Is anyone else running McAfee HBSS on affected Macs?
- Contributor
- October 3, 2016
Put me down for a ditto.
Seeing same thing on 2 of our machines. I re-imaged this machine... and within days the issue was back.
Process: TextEdit [17320]
Path: /Applications/TextEdit.app/Contents/MacOS/TextEdit
Identifier: com.apple.TextEdit
Version: 1.11 (325)
Build Info: TextEdit-325000000000000~16
Code Type: X86-64 (Native)
Parent Process: ??? [1]
Responsible: TextEdit [17320]
User ID: 679800056
Date/Time: 2016-10-03 11:43:31.893 -0500
OS Version: Mac OS X 10.11.6 (15G31)
Report Version: 11
Anonymous UUID: 87DD60D4-A884-D1B9-3AC3-CB1D56BA2E34
Time Awake Since Boot: 320000 seconds
System Integrity Protection: enabled
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_BAD_INSTRUCTION (SIGILL)
Exception Codes: 0x0000000000000001, 0x0000000000000000
Exception Note: EXC_CORPSE_NOTIFY
Application Specific Information:
Application Specific Signatures:
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 libsystem_secinit.dylib 0x00007fff9861c193 libsecinit_setup_secinitd_client 1543
1 libsystem_secinit.dylib 0x00007fff9861bb2a _libsecinit_initialize_once 13
2 libdispatch.dylib 0x00007fff9537d40b _dispatch_client_callout 8
3 libdispatch.dylib 0x00007fff9537d303 dispatch_once_f 67
4 libSystem.B.dylib 0x00007fff967c4a0c libSystem_initializer 131
5 dyld 0x00007fff6a52110b ImageLoaderMachO::doModInitFunctions(ImageLoader::LinkContext const&) 265
6 dyld 0x00007fff6a521284 ImageLoaderMachO::doInitialization(ImageLoader::LinkContext const&) 40
7 dyld 0x00007fff6a51d8bd ImageLoader::recursiveInitialization(ImageLoader::LinkContext const&, unsigned int, ImageLoader::InitializerTimingList&, ImageLoader::UninitedUpwards&) 305
8 dyld 0x00007fff6a51d852 ImageLoader::recursiveInitialization(ImageLoader::LinkContext const&, unsigned int, ImageLoader::InitializerTimingList&, ImageLoader::UninitedUpwards&) 198
9 dyld 0x00007fff6a51d852 ImageLoader::recursiveInitialization(ImageLoader::LinkContext const&, unsigned int, ImageLoader::InitializerTimingList&, ImageLoader::UninitedUpwards&) 198
10 dyld 0x00007fff6a51d852 ImageLoader::recursiveInitialization(ImageLoader::LinkContext const&, unsigned int, ImageLoader::InitializerTimingList&, ImageLoader::UninitedUpwards&) 198
11 dyld 0x00007fff6a51d852 ImageLoader::recursiveInitialization(ImageLoader::LinkContext const&, unsigned int, ImageLoader::InitializerTimingList&, ImageLoader::UninitedUpwards&) 198
12 dyld 0x00007fff6a51d852 ImageLoader::recursiveInitialization(ImageLoader::LinkContext const&, unsigned int, ImageLoader::InitializerTimingList&, ImageLoader::UninitedUpwards&) 198
13 dyld 0x00007fff6a51d852 ImageLoader::recursiveInitialization(ImageLoader::LinkContext const&, unsigned int, ImageLoader::InitializerTimingList&, ImageLoader::UninitedUpwards&) 198
14 dyld 0x00007fff6a51d743 ImageLoader::processInitializers(ImageLoader::LinkContext const&, unsigned int, ImageLoader::InitializerTimingList&, ImageLoader::UninitedUpwards&) 127
15 dyld 0x00007fff6a51d9b3 ImageLoader::runInitializers(ImageLoader::LinkContext const&, ImageLoader::InitializerTimingList&) 75
16 dyld 0x00007fff6a5100f1 dyld::initializeMainExecutable() 208
17 dyld 0x00007fff6a513d98 dyld::_main(macho_header const, unsigned long, int, char const, char const, char const, unsigned long) 3596
18 dyld 0x00007fff6a50f276 dyldbootstrap::start(macho_header const, int, char const, long, macho_header const, unsigned long) 512
19 dyld 0x00007fff6a50f036 _dyld_start 54
Thread 0 crashed with X86 Thread State (64-bit): rax: 0x0000000000000079 rbx: 0x00007fff5bdbe210 rcx: 0x2b0004a263ead347 rdx: 0x00007fff9861cbd5 rdi: 0x0000000000000000 rsi: 0x00007fb19b0040f4 rbp: 0x00007fff5bdbea90 rsp: 0x00007fff5bdbe1f0 r8: 0x0000000000000002 r9: 0x00007fff9861cbf0 r10: 0x0000000000000013 r11: 0x0000004dc0dba175 r12: 0x00007fb19ae00220 r13: 0x00007fb19b0040b4 r14: 0x00007fb19b0040b4 r15: 0x00007fb19b00414c rip: 0x00007fff9861c193 rfl: 0x0000000000010206 cr2: 0x00007fff76c141c0
Logical CPU: 3
Error Code: 0x00000000
Trap Number: 6
Binary Images: 0x103e3e000 - 0x103e58ff7 com.apple.TextEdit (1.11 - 325) <073BA5FE-F5D6-326E-9A32-64F3D480BC07> /Applications/TextEdit.app/Contents/MacOS/TextEdit 0x7fff6a50e000 - 0x7fff6a545a47 dyld (360.22) <DC81CC9D-651A-3A45-8809-928282052BD3> /usr/lib/dyld 0x7fff8331f000 - 0x7fff83328ff3 libsystem_notify.dylib (150.40.1) <D48BDE34-0F7E-34CA-A0FF-C578E39987CC> /usr/lib/system/libsystem_notify.dylib 0x7fff834d4000 - 0x7fff83569fff com.apple.ink.framework (10.9 - 214) <1F76CF36-3F79-36B8-BC37-C540AF34B338> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink 0x7fff8356a000 - 0x7fff8356afff com.apple.ApplicationServices (48 - 48) <ADD57D3A-142F-3EF5-BFD8-EACD82164884> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices 0x7fff83577000 - 0x7fff841a0ff7 com.apple.AppKit (6.9 - 1404.47) <F3411F6E-DD87-34D0-8C68-C69B2205E41D> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit 0x7fff841a9000 - 0x7fff842d6ff3 com.apple.CoreText (352.0 - 494.12) <ADBE8355-D4F5-3316-A6C4-D641D615CEC4> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText 0x7fff842d7000 - 0x7fff842dafff libsystem_sandbox.dylib (460.60.2) <2A68B39C-B786-3A05-87A2-56E688469FB8> /usr/lib/system/libsystem_sandbox.dylib 0x7fff8432d000 - 0x7fff84332fff com.apple.DiskArbitration (2.7 - 2.7) <F55902AA-5316-3255-A701-FDED5B553065> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration 0x7fff84333000 - 0x7fff84333ff7 liblaunch.dylib (765.50.8) <834ED605-5114-3641-AA4D-ECF31B801C50> /usr/lib/system/liblaunch.dylib 0x7fff8523d000 - 0x7fff8523dfff com.apple.Accelerate (1.10 - Accelerate 1.10) <185EC96A-5AF0-3620-A4ED-4D3654D25B39> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate 0x7fff852e2000 - 0x7fff852ebff7 com.apple.CommonAuth (4.0 - 2.0) <4B8673E1-3697-3FE2-8D30-AC7AC5D4F8BF> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth 0x7fff85493000 - 0x7fff85497fff libGIF.dylib (1459) <7C84B660-04BC-3D05-8C02-A7FBE51FD77B> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib 0x7fff854f7000 - 0x7fff85528fff com.apple.GSS (4.0 - 2.0) <B490333A-3B3E-397A-AD75-68846E9A9140> /System/Library/Frameworks/GSS.framework/Versions/A/GSS 0x7fff85600000 - 0x7fff85600fff libenergytrace.dylib (10.40.1) <0A491CA7-3451-3FD5-999A-58AB4362682B> /usr/lib/libenergytrace.dylib 0x7fff85604000 - 0x7fff8560cfff libsystem_networkextension.dylib (385.40.36) <66095DC7-6539-38F2-95EE-458F15F6D014> /usr/lib/system/libsystem_networkextension.dylib 0x7fff85613000 - 0x7fff85679ff7 libsystem_network.dylib (583.50.1) <B52DAB73-92DC-3DA7-B9F4-B899D66445C1> /usr/lib/system/libsystem_network.dylib 0x7fff8567f000 - 0x7fff8570cdd7 com.apple.AppleJPEG (1.0 - 1) <BF7EDBDB-A52D-37F7-BDE4-EAD49310D7A9> /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG 0x7fff85c14000 - 0x7fff85ef9ffb com.apple.CoreServices.CarbonCore (1136.2 - 1136.2) <2DBAFC9A-6CD6-351D-B1F4-87D81AA6D640> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore 0x7fff85efa000 - 0x7fff85efafff libOpenScriptingUtil.dylib (169.1) <AD0DAC8A-9849-3077-999F-9AEC6112BDAB> /usr/lib/libOpenScriptingUtil.dylib 0x7fff85efb000 - 0x7fff85efcfff libsystem_blocks.dylib (65) <1244D9D5-F6AA-35BB-B307-86851C24B8E5> /usr/lib/system/libsystem_blocks.dylib 0x7fff86b9c000 - 0x7fff86ba1ff7 libmacho.dylib (875.1) <318264FA-58F1-39D8-8285-1F6254EE410E> /usr/lib/system/libmacho.dylib 0x7fff86db7000 - 0x7fff86dd3ff3 libresolv.9.dylib (60) <A650B5C8-1950-36A0-86D1-0B2465318BFA> /usr/lib/libresolv.9.dylib 0x7fff86e02000 - 0x7fff86e26fff libJPEG.dylib (1459) <B274689A-56C5-3DBE-9E4E-049608BBD50B> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib 0x7fff86e27000 - 0x7fff86e2cfff com.apple.TCC (1.0 - 1) <F5EEB2D3-9517-3975-97BE-22CB8E11B8A3> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC 0x7fff86e2d000 - 0x7fff86f3cfe7 libvDSP.dylib (563.5) <9AB6CA3C-4F0E-35E6-9184-9DF86E7C3DAD> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib 0x7fff86f6d000 - 0x7fff86f76ff7 libsystem_pthread.dylib (138.10.4) <3DD1EF4C-1D1B-3ABF-8CC6-B3B1CEEE9559> /usr/lib/system/libsystem_pthread.dylib 0x7fff870c8000 - 0x7fff87212ff7 com.apple.coreui (2.1 - 366.1) <8138636F-A0A7-31C7-896C-5F5747FA1B2A> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI 0x7fff873c6000 - 0x7fff873c9ffb libScreenReader.dylib (426.42) <16FC79D1-4573-3E90-945F-CBA22D5185FD> /usr/lib/libScreenReader.dylib 0x7fff873ca000 - 0x7fff873d5fff com.apple.CrashReporterSupport (10.11 - 718) <05892B57-F2CD-3C84-B984-0417F6B361DB> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport 0x7fff87b28000 - 0x7fff87b30ffb libsystem_dnssd.dylib (625.60.4) <80189998-32B0-316C-B5C5-53857486713D> /usr/lib/system/libsystem_dnssd.dylib 0x7fff87b31000 - 0x7fff87cffff3 com.apple.QuartzCore (1.11 - 410.14) <076BDE58-8AED-3D47-84FD-548CF8E8EDB9> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore 0x7fff87db5000 - 0x7fff87dfbff7 libauto.dylib (186) <999E610F-41FC-32A3-ADCA-5EC049B65DFB> /usr/lib/libauto.dylib 0x7fff87dfc000 - 0x7fff87e89fef libsystem_c.dylib (1082.60.1) <28733D22-553E-3CBC-8D2C-EDCEB46E46AF> /usr/lib/system/libsystem_c.dylib 0x7fff881ce000 - 0x7fff8823dfff com.apple.SearchKit (1.4.0 - 1.4.0) <F159A888-34CA-36F1-AC8E-EB1B38C9DFB3> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit 0x7fff88304000 - 0x7fff8830ffff libkxld.dylib (3248.60.10) <991CDFE9-AB87-321B-A4B2-5EFE64DDCF74> /usr/lib/system/libkxld.dylib 0x7fff885c6000 - 0x7fff885c8fff libsystem_coreservices.dylib (19.2) <1B3F5AFC-FFCD-3ECB-8B9A-5538366FB20D> /usr/lib/system/libsystem_coreservices.dylib 0x7fff88d20000 - 0x7fff88d54ff7 com.apple.CoreVideo (1.8 - 191.3) <1AA24A1B-CB84-3F6B-B6DE-11494542649C> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo 0x7fff88de7000 - 0x7fff890dcfff com.apple.HIToolbox (2.1.1 - 807.2) <36413C45-36AF-34EF-9C0E-F18B31D1E565> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox 0x7fff890e6000 - 0x7fff89128ff7 com.apple.Metal (56.6 - 56.6) <30518711-8D00-3759-AA19-800D3C88E693> /System/Library/Frameworks/Metal.framework/Versions/A/Metal 0x7fff89409000 - 0x7fff8942dfff com.apple.MultitouchSupport.framework (304.12 - 304.12) <65CB7653-EACD-3ADB-ABB6-2E0671708301> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport 0x7fff8956f000 - 0x7fff8961ffff com.apple.backup.framework (1.7.4 - 1.7.4) <F304E9D1-991A-379E-9659-BF85C35B4808> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup 0x7fff896b3000 - 0x7fff896b3fff com.apple.Cocoa (6.11 - 22) <807787AB-D231-3F51-A99B-A9314623C571> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa 0x7fff896c7000 - 0x7fff8973cfff com.apple.framework.IOKit (2.0.2 - 1179.50.2) <A509D3AE-9D48-31B7-89C7-326A7A2007B2> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit 0x7fff897dd000 - 0x7fff897eeff7 libsystem_trace.dylib (201.10.3) <1DD0C1FD-74E2-3949-9C2C-B81D19C2CA5E> /usr/lib/system/libsystem_trace.dylib 0x7fff897ef000 - 0x7fff89a85fff libmecabra.dylib (696.5) <EF6C0BD4-5FE8-34FB-8ADF-69A53CEC97A9> /usr/lib/libmecabra.dylib 0x7fff89b2b000 - 0x7fff89b2bfff com.apple.audio.units.AudioUnit (1.13 - 1.13) <378B5292-F216-32AB-B628-8C33A72D7052> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit 0x7fff89ea7000 - 0x7fff89eb3fff com.apple.SpeechRecognitionCore (2.2.7 - 2.2.7) <6BA06290-D4A3-351C-87F9-B61EF61FF055> /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/SpeechRecognitionCore 0x7fff8a2af000 - 0x7fff8a2fbffb com.apple.HIServices (1.22 - 550) <6B76B41C-CF5A-34C4-89F4-EFD7CA3D1C9D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices 0x7fff8a2fc000 - 0x7fff8a47afff com.apple.UIFoundation (1.0 - 436.1) <AABB5267-E7B7-3D75-B051-E665BDA8DEF4> /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation 0x7fff8a47b000 - 0x7fff8a483fff com.apple.NetFS (6.0 - 4.0) <842A5346-24C3-3F22-9ECF-E586A10EA1F2> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS 0x7fff8a6fd000 - 0x7fff8a6fdfff com.apple.Accelerate.vecLib (3.10 - vecLib 3.10) <054DFE32-737D-3211-9A14-0FC5E1A880E3> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib 0x7fff8a7aa000 - 0x7fff8a7fdff7 libc+.1.dylib (120.1) <8FC3D139-8055-3498-9AC5-6467CB7F4D14> /usr/lib/libc.1.dylib 0x7fff8a811000 - 0x7fff8a812fff libDiagnosticMessagesClient.dylib (100) <4243B6B4-21E9-355B-9C5A-95A216233B96> /usr/lib/libDiagnosticMessagesClient.dylib 0x7fff8a92d000 - 0x7fff8ab38fff libFosl_dynamic.dylib (16.24) <5F9DB82D-FD4B-3952-8531-CE020F93ED49> /usr/lib/libFosl_dynamic.dylib 0x7fff8ab39000 - 0x7fff8ab44ff7 libcommonCrypto.dylib (60075.50.1) <93732261-34B4-3914-B7A2-90A81A182DBA> /usr/lib/system/libcommonCrypto.dylib 0x7fff8b11b000 - 0x7fff8b14affb libsystem_m.dylib (3105) <08E1A4B2-6448-3DFE-A58C-ACC7335BE7E4> /usr/lib/system/libsystem_m.dylib 0x7fff8b14b000 - 0x7fff8b1f2fff com.apple.LanguageModeling (1.0 - 1) <58C18A47-BDE7-3CBE-81C0-797029D170A1> /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling 0x7fff8b46a000 - 0x7fff8b4afff3 libFontRegistry.dylib (155.2) <A70DD497-35F3-34DA-9C19-F4B90080E961> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib 0x7fff8b4b0000 - 0x7fff8b539ff7 com.apple.PerformanceAnalysis (1.0 - 1) <1BC106BB-3C7F-37C9-8496-43F584A6F304> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis 0x7fff8b590000 - 0x7fff8b593ffb libdyld.dylib (360.22) <1F9FCF2C-5E94-3F2D-B4A5-1238587AA5C6> /usr/lib/system/libdyld.dylib 0x7fff8b626000 - 0x7fff8b63dff7 libsystem_asl.dylib (323.50.1) <41F8E11F-1BD0-3F1D-BA3A-AA1577ED98A9> /usr/lib/system/libsystem_asl.dylib 0x7fff8b64c000 - 0x7fff8b650fff libcache.dylib (75) <9548AAE9-2AB7-3525-9ECE-A2A7C4688447> /usr/lib/system/libcache.dylib 0x7fff8bbc2000 - 0x7fff8bbd0ff7 libbz2.1.0.dylib (38) <28E54258-C0FE-38D4-AB76-1734CACCB344> /usr/lib/libbz2.1.0.dylib 0x7fff8bbd1000 - 0x7fff8bc22ff7 libcups.2.dylib (435.2) <91584A40-214D-33E8-A613-CE22289037C8> /usr/lib/libcups.2.dylib 0x7fff8bc23000 - 0x7fff8bc3afff libmarisa.dylib (4) <E4919B03-D9BD-3AF8-B436-C415C98E3F0A> /usr/lib/libmarisa.dylib 0x7fff8cf88000 - 0x7fff8d096ff3 com.apple.desktopservices (1.10.3 - 1.10.3) <3A6906D4-C0B8-30D1-B589-0466E5E42B69> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv 0x7fff8d0aa000 - 0x7fff8d118ff7 com.apple.ApplicationServices.ATS (377 - 394.4) <9779E916-0788-3CAC-B1EC-F68BCB12A2B6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS 0x7fff8d2c5000 - 0x7fff8d2f0ffb libarchive.2.dylib (33.20.2) <6C370A21-63FD-3A68-B4B3-5333F24B770B> /usr/lib/libarchive.2.dylib 0x7fff8d3bf000 - 0x7fff8d3d9ff3 liblzma.5.dylib (10) <CC03591B-FA57-3CA5-AC81-0D76033AC0CE> /usr/lib/liblzma.5.dylib 0x7fff8d426000 - 0x7fff8d472fff com.apple.print.framework.PrintCore (11.2 - 472.2) <5AE8AA6B-CE09-397D-B0D4-0F9CCBF1F77D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore 0x7fff8d47a000 - 0x7fff8d47efff libpam.2.dylib (20) <CFCD19BD-87BC-3F2B-BB1C-4C23E8E55F1A> /usr/lib/libpam.2.dylib 0x7fff8d4e5000 - 0x7fff8d51dff7 com.apple.RemoteViewServices (2.0 - 101) <B2881449-8CFE-3D1C-B4BF-155640392533> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices 0x7fff8d536000 - 0x7fff8d5befff com.apple.CoreSymbolication (3.1 - 58048.1) <4730422E-4178-34F9-8550-BB92F2A4F44B> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication 0x7fff8d5bf000 - 0x7fff8d5ceffb com.apple.LangAnalysis (1.7.0 - 1.7.0) <18D21123-A3E7-3851-974A-08E5D4540475> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis 0x7fff8d5eb000 - 0x7fff8d5f9fff libxar.1.dylib (302) <03207F66-2C4A-3DBD-8D81-70F4C85903C4> /usr/lib/libxar.1.dylib 0x7fff8d62e000 - 0x7fff8d9c3fdb com.apple.vImage (8.0 - 8.0) <4BAC9B6F-7482-3580-8787-AB0A5B4D331B> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage 0x7fff8d9f4000 - 0x7fff8da50fff libTIFF.dylib (1459) <1E1839C3-2C99-38B8-A729-788459576858> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib 0x7fff8dca3000 - 0x7fff8dca6fff com.apple.IOSurface (108.2.3 - 108.2.3) <52E51D16-42E9-3DDB-A16C-48225EF262C4> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface 0x7fff8e09c000 - 0x7fff8e09eff7 com.apple.xpc.ServiceManagement (1.0 - 1) <D96D7A6D-EDEB-35EE-B5D9-E33A3BF011B5> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement 0x7fff8e128000 - 0x7fff8e3ceff7 com.apple.CoreData (120 - 641.3) <A29A5491-6169-372B-828F-84EE0CFD4BC4> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData 0x7fff8e3cf000 - 0x7fff8e3f8ff7 libxslt.1.dylib (14.4) <72CD1CA4-1FBD-3672-ADCE-A89AB741689A> /usr/lib/libxslt.1.dylib 0x7fff8e3f9000 - 0x7fff8e41bff7 com.apple.Sharing (442.13.6 - 442.13.6) <DDD2811C-6ECB-32F2-8EE1-69BF9657B4A8> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing 0x7fff8e41c000 - 0x7fff8e445fff libsystem_info.dylib (477.50.4) <FAA9226D-64DE-3769-A6D8-6CABA4B7FF4D> /usr/lib/system/libsystem_info.dylib 0x7fff8ea29000 - 0x7fff8ea63ff7 com.apple.DebugSymbols (132 - 132) <23A42C53-B941-3871-9EE2-4C87A46005B5> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols 0x7fff8ea64000 - 0x7fff8ea77fff com.apple.CoreBluetooth (1.0 - 1) <E54CA9A2-A5C6-30C5-9D6E-8472DBA9371E> /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth 0x7fff8ebb1000 - 0x7fff8fdfcfeb com.apple.CoreGraphics (1.600.0 - 960.3) <407FA367-204F-389E-8E33-0435E3B56D40> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics 0x7fff8fdfd000 - 0x7fff8ffc3ff7 com.apple.ImageIO.framework (3.3.0 - 1459) <228306DC-0C7F-3D69-92FA-B2E46E47AA9F> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO 0x7fff8ffc4000 - 0x7fff8ffcffff libGL.dylib (12.1) <70D51643-04AC-3400-8F11-A6FC25985289> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib 0x7fff9006e000 - 0x7fff90073ff3 libunwind.dylib (35.3) <F6EB48E5-4D12-359A-AB54-C937FBBE9043> /usr/lib/system/libunwind.dylib 0x7fff90130000 - 0x7fff9033dfff libicucore.A.dylib (551.51.4) <3899B146-3840-3D4A-8C4A-FE391D5D25C7> /usr/lib/libicucore.A.dylib 0x7fff90344000 - 0x7fff90433ff7 libxml2.2.dylib (29.10) <B3B03292-7E1A-34AB-888C-3D49D63D60C6> /usr/lib/libxml2.2.dylib 0x7fff904cb000 - 0x7fff904e4fff com.apple.CFOpenDirectory (10.11 - 194) <11F95672-55E0-3F9D-9171-5E8C56AEE948> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory 0x7fff90592000 - 0x7fff90682ff7 libJP2.dylib (1459) <5212E346-B7FC-31F4-B4F7-CF1DD9BBAFBB> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib 0x7fff90685000 - 0x7fff90729fff com.apple.Bluetooth (4.4.6 - 4.4.6f1) <F8E54D34-DAAB-319F-8AE7-F3C55CA0CC68> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth 0x7fff9072a000 - 0x7fff90ba0fff com.apple.CoreFoundation (6.9 - 1258.1) <943A1383-DA6A-3DC0-ABCD-D9AEB3D0D34D> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff91095000 - 0x7fff91098fff libCoreVMClient.dylib (119.5) <560D70FB-709F-3030-96C9-F249FCB7DA6D> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib 0x7fff91099000 - 0x7fff910f7fff com.apple.SystemConfiguration (1.14 - 1.14) <D801FAD7-5A2D-3E5E-9F44-B6C9B8BEA747> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration 0x7fff91345000 - 0x7fff91773fff com.apple.vision.FaceCore (3.3.1 - 3.3.1) <E54028EA-4217-3078-A2B1-C52E4214D59E> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore 0x7fff917a6000 - 0x7fff917aefff com.apple.CoreServices.FSEvents (1223.10.1 - 1223.10.1) <7F5B7A23-BC1D-3FA9-A9B8-D534F1E1979A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/FSEvents 0x7fff917c5000 - 0x7fff917ddfef libcompression.dylib (28) <E7601B62-1053-369D-8A9E-91CF86239220> /usr/lib/libcompression.dylib 0x7fff918cb000 - 0x7fff918cdff7 libquarantine.dylib (80) <0F4169F0-0C84-3A25-B3AE-E47B3586D908> /usr/lib/system/libquarantine.dylib 0x7fff91be9000 - 0x7fff91c38ff7 com.apple.opencl (2.7.0 - 2.7.0) <39581F1A-04FE-3CCA-9118-E9BB9053F7A1> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL 0x7fff91d71000 - 0x7fff91d8dfff com.apple.GenerationalStorage (2.0 - 239.1) <8C821448-4294-3736-9CEF-467C93785CB9> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalStorage 0x7fff91dc7000 - 0x7fff921c3fff libLAPACK.dylib (1162.2) <987E42B0-5108-3065-87F0-9DF7616A8A06> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib 0x7fff9236b000 - 0x7fff923a9ff7 libGLImage.dylib (12.1) <BB1F1A93-5101-3906-AB17-8D83FCB200F9> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib 0x7fff923aa000 - 0x7fff923ebff7 libGLU.dylib (12.1) <CD7A5916-3E3C-3EF3-A275-B281016B99CB> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib 0x7fff9255a000 - 0x7fff9277bff7 com.apple.CoreImage (11.4.0 - 366.4.19) <F5B7B115-E43A-3C61-A6AD-EFCDE7FC43A1> /System/Library/Frameworks/CoreImage.framework/Versions/A/CoreImage 0x7fff92782000 - 0x7fff92832fe7 libvMisc.dylib (563.5) <6D73C20D-D1C4-3BA5-809B-4B597C15AA86> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib 0x7fff92861000 - 0x7fff92878ff7 libsystem_coretls.dylib (83.40.5) <C90DAE38-4082-381C-A185-2A6A8B677628> /usr/lib/system/libsystem_coretls.dylib 0x7fff9287e000 - 0x7fff92a24ff7 com.apple.audio.toolbox.AudioToolbox (1.13 - 1.13) <370E95BC-956C-3962-86CC-0A14CF6A0389> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox 0x7fff92ab8000 - 0x7fff92ab8ff7 libunc.dylib (29) <DDB1E947-C775-33B8-B461-63E5EB698F0E> /usr/lib/system/libunc.dylib 0x7fff92ab9000 - 0x7fff92afeff7 com.apple.coreservices.SharedFileList (24.4 - 24.5) <1D2AD77B-778F-3253-A295-3D0A32A8121C> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SharedFileList.framework/Versions/A/SharedFileList 0x7fff93393000 - 0x7fff933a9ff7 libLinearAlgebra.dylib (1162.2) <FFE54EDF-F06F-3C0A-864A-4CA7BBFD4B2D> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLinearAlgebra.dylib 0x7fff933aa000 - 0x7fff933bbfff libcmph.dylib (6) <BA4BF2C6-7F4E-33B8-9DD7-619C9EB83ECF> /usr/lib/libcmph.dylib 0x7fff93627000 - 0x7fff9362dfff com.apple.IOAccelerator (205.11 - 205.11) <C51BF724-F8E8-3B9F-806E-A00C65056445> /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator 0x7fff9362e000 - 0x7fff93990f3f libobjc.A.dylib (680) <7489D2D6-1EFD-3414-B18D-2AECCCC90286> /usr/lib/libobjc.A.dylib 0x7fff93c00000 - 0x7fff93cf2ff7 libiconv.2.dylib (44) <F05A0A5A-92A9-3668-8F20-F27CBDA26BE9> /usr/lib/libiconv.2.dylib 0x7fff93f02000 - 0x7fff93f29fff com.apple.ChunkingLibrary (167 - 167) <AD7F285C-005E-36BB-98A3-5826413533BE> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary 0x7fff93f2a000 - 0x7fff93f64fff com.apple.QD (3.12 - 302) <0FE53180-2895-3D14-A1E7-F82DE1D106E1> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD 0x7fff93f8f000 - 0x7fff93fb8ff7 libxpc.dylib (765.50.8) <54D1328E-054E-3DAA-89E2-375722F9D18F> /usr/lib/system/libxpc.dylib 0x7fff941df000 - 0x7fff941e2ff7 libCoreFSCache.dylib (119.5) <2389D7DA-B8EF-3EB4-AAAF-FBEDE01CDECA> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib 0x7fff94239000 - 0x7fff9428efff com.apple.AE (701 - 701) <AD492742-F884-386B-A450-FAC281B9FFA4> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE 0x7fff94379000 - 0x7fff94380ff7 libcompiler_rt.dylib (62) <A13ECF69-F59F-38AE-8609-7B731450FBCD> /usr/lib/system/libcompiler_rt.dylib 0x7fff94381000 - 0x7fff943e8fff com.apple.framework.CoreWiFi (11.0 - 1101.20) <993592F1-B3F1-3FAD-87BD-EA83C361BCCF> /System/Library/PrivateFrameworks/CoreWiFi.framework/Versions/A/CoreWiFi 0x7fff94460000 - 0x7fff94462fff com.apple.loginsupport (1.0 - 1) <9B2F5F9B-ED38-313F-B798-D2B667BCD6B5> /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.framework/Versions/A/loginsupport 0x7fff94463000 - 0x7fff94463fff com.apple.CoreServices (728.13 - 728.13) <E3DFECD2-ECEA-3242-972D-95B9646B57B8> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices 0x7fff94dfd000 - 0x7fff94e09fff com.apple.speech.synthesis.framework (5.4.12 - 5.4.12) <71DA00B8-5EA2-326B-8814-59DB25512F65> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis 0x7fff94e20000 - 0x7fff94e2efff com.apple.opengl (12.1.0 - 12.1.0) <0718DB60-BA4F-3CF7-A117-10A2515D931F> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL 0x7fff94e40000 - 0x7fff94f3cff7 libFontParser.dylib (158.6) <267A9AE4-4138-3112-8D73-BDFDC96568FF> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib 0x7fff94faf000 - 0x7fff95023ff7 com.apple.Heimdal (4.0 - 2.0) <5D365381-8B5E-3259-8867-FC4A7D307BDE> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal 0x7fff95024000 - 0x7fff95030ff7 com.apple.OpenDirectory (10.11 - 194) <31A67AD5-5CC2-350A-96D7-821DF4BC4196> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory 0x7fff9521a000 - 0x7fff95237ff7 com.apple.AppleVPAFramework (2.1.2 - 2.1.2) <41378C0B-B56A-3A73-9BD0-E06FA1F87B8C> /System/Library/PrivateFrameworks/AppleVPA.framework/Versions/A/AppleVPA 0x7fff9528d000 - 0x7fff952bcff7 com.apple.DictionaryServices (1.2 - 250.3) <30250542-CBAA-39C1-91AA-B57A5DE17594> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices 0x7fff952bd000 - 0x7fff952d9ff7 libextension.dylib (78) <FD952DA6-BBEC-3CB6-98B3-E1D111C5C54E> /usr/lib/libextension.dylib 0x7fff952da000 - 0x7fff9537afff com.apple.Metadata (10.7.0 - 972.34) <A58195C5-5D5C-32D5-8BBB-F4D32201E5AA> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata 0x7fff9537b000 - 0x7fff953a8fff libdispatch.dylib (501.40.12) <C7499857-61A5-3D7D-A5EA-65DCC8C3DF92> /usr/lib/system/libdispatch.dylib 0x7fff95556000 - 0x7fff955b4fff com.apple.CoreServices.OSServices (728.13 - 728.13) <27C12B92-7845-38DD-B82D-DC5B678352D6> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices 0x7fff955cc000 - 0x7fff955ccff7 libkeymgr.dylib (28) <8371CE54-5FDD-3CE9-B3DF-E98C761B6FE0> /usr/lib/system/libkeymgr.dylib 0x7fff955cd000 - 0x7fff955d2ff7 libheimdal-asn1.dylib (453.40.10) <981DE40B-FA16-36F7-BE92-8C8A115D6CD9> /usr/lib/libheimdal-asn1.dylib 0x7fff95c92000 - 0x7fff95c92fff libmetal_timestamp.dylib (600.0.44.2) <DEEA1127-7A5D-3EF2-A4B2-AE125CBA5DB5> /System/Library/PrivateFrameworks/GPUCompiler.framework/libmetal_timestamp.dylib 0x7fff95cd1000 - 0x7fff95cedff7 libsystem_malloc.dylib (67.40.1) <5748E8B2-F81C-34C6-8B13-456213127678> /usr/lib/system/libsystem_malloc.dylib 0x7fff95cee000 - 0x7fff95d10fff com.apple.IconServices (68.1 - 68.1) <CDEEDBE6-F53B-3BA1-82D4-23BCA3DD8949> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices 0x7fff95f92000 - 0x7fff95f9afff libGFXShared.dylib (12.1) <5A0C2493-200C-30BE-97D5-8E8C0B8E604D> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib 0x7fff95f9b000 - 0x7fff96235ff3 com.apple.security (7.0 - 57337.60.2) <E2E553E7-28C4-3296-B3B6-BB1B3CA73943> /System/Library/Frameworks/Security.framework/Versions/A/Security 0x7fff96237000 - 0x7fff96256ff7 com.apple.framework.Apple80211 (11.0 - 1121.34.2) <90477FAE-B835-3931-80FB-FDFF02B21D9D> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211 0x7fff967c3000 - 0x7fff967c4ffb libSystem.B.dylib (1226.10.1) <ECAA07BE-A114-3461-AA13-C57838775FC2> /usr/lib/libSystem.B.dylib 0x7fff967c5000 - 0x7fff967c7ff7 libsystem_configuration.dylib (802.40.13) <3DEB7DF9-6804-37E1-BC83-0166882FF0FF> /usr/lib/system/libsystem_configuration.dylib 0x7fff967c8000 - 0x7fff967d3ff7 libChineseTokenizer.dylib (16) <79B8C67A-3061-3C78-92CD-4650719E68D4> /usr/lib/libChineseTokenizer.dylib 0x7fff96812000 - 0x7fff96889feb libcorecrypto.dylib (335.50.1) <B5C05FD7-A540-345A-87BF-8E41848A3C17> /usr/lib/system/libcorecrypto.dylib 0x7fff9695b000 - 0x7fff969f1fff com.apple.ColorSync (4.9.0 - 4.9.0) <8FC37E20-6579-3CB2-9D49-BC39FC38DF87> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync 0x7fff969f2000 - 0x7fff96b59fff libBLAS.dylib (1162.2) <A1398FE0-39D2-33EA-9A0F-B2644EEA29A0> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib 0x7fff96e90000 - 0x7fff96efffff com.apple.datadetectorscore (7.0 - 460) <E8616F01-90AC-3863-B18C-426E6DD1ACDE> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore 0x7fff96f00000 - 0x7fff96f10fff libbsm.0.dylib (34) <7E14504C-A8B0-3574-B6EB-5D5FABC72926> /usr/lib/libbsm.0.dylib 0x7fff96f3b000 - 0x7fff96f65ff7 libcabi.dylib (307.2) <922EFB36-0E9E-315B-8270-E81AC43472C0> /usr/lib/libc+abi.dylib 0x7fff96f66000 - 0x7fff96fdaff3 com.apple.securityfoundation (6.0 - 55126) <DAA4FDD0-7F84-30AA-BE6F-96BB9F871F07> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation 0x7fff97004000 - 0x7fff9701efff com.apple.Kerberos (3.0 - 1) <1B4744BF-E5AE-38E2-AA56-E22D3270F2E8> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos 0x7fff9701f000 - 0x7fff97070fff com.apple.audio.CoreAudio (4.3.0 - 4.3.0) <EA7D4F3B-062B-3C81-A98C-C89264D00D48> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio 0x7fff97071000 - 0x7fff97079fef libsystem_platform.dylib (74.40.2) <29A905EF-6777-3C33-82B0-6C3A88C4BA15> /usr/lib/system/libsystem_platform.dylib 0x7fff970f1000 - 0x7fff970f9fff libcopyfile.dylib (127) <A48637BC-F3F2-34F2-BB68-4C65FD012832> /usr/lib/system/libcopyfile.dylib 0x7fff970fa000 - 0x7fff9710bff7 libz.1.dylib (61.20.1) <B3EBB42F-48E3-3287-9F0D-308E04D407AC> /usr/lib/libz.1.dylib 0x7fff972e9000 - 0x7fff972fafff libSparseBLAS.dylib (1162.2) <EBEB3848-3468-342A-91A6-5C47F2369CD9> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparseBLAS.dylib 0x7fff973b5000 - 0x7fff9763cfff com.apple.CFNetwork (760.6.3 - 760.6.3) <8CB9CB2E-D0FB-31D4-A1AE-2A5FE028AD6B> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork 0x7fff97736000 - 0x7fff97737ffb libremovefile.dylib (41) <552EF39E-14D7-363E-9059-4565AC2F894E> /usr/lib/system/libremovefile.dylib 0x7fff97738000 - 0x7fff9785ffff com.apple.LaunchServices (728.13 - 728.13) <DF9A69C3-06AD-3062-A40A-50ED12CA18CA> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices 0x7fff9791a000 - 0x7fff9793fff7 libPng.dylib (1459) <F3A3BCAD-244C-3014-9D44-5ED179BD391D> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib 0x7fff97940000 - 0x7fff97a64fff libsqlite3.dylib (216.4) <280D67B8-F93D-3587-A146-19F36C817548> /usr/lib/libsqlite3.dylib 0x7fff9861b000 - 0x7fff9861cfff libsystem_secinit.dylib (20) <32B1A8C6-DC84-3F4F-B8CE-9A52B47C3E6B> /usr/lib/system/libsystem_secinit.dylib 0x7fff986a4000 - 0x7fff986aaff7 com.apple.speech.recognition.framework (5.1.1 - 5.1.1) <9E5A980A-F455-32D5-BBEE-3BD6018CC45E> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition 0x7fff98735000 - 0x7fff98785ff7 com.apple.Symbolication (1.4 - 58044) <F70BF765-FBE9-3F1E-85CA-BB2F8E53E8C2> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication 0x7fff98974000 - 0x7fff989dfff7 com.apple.framework.CoreWLAN (11.0 - 1101.20) <3B35C543-7FCE-333F-80C1-432FA41DDCDE> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN 0x7fff989e0000 - 0x7fff989eafff com.apple.NetAuth (6.0 - 6.0) <D692B1EF-534F-3892-8E2F-2BBA7C8AFD74> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth 0x7fff989f9000 - 0x7fff989fbff7 libRadiance.dylib (1459) <43B09AB2-B747-3EA0-A0AF-9A33B3A449D2> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib 0x7fff989fc000 - 0x7fff98d50fff com.apple.Foundation (6.9 - 1259) <71A9D3A0-0B1F-3E3A-86F3-1486365A6EF2> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff98e00000 - 0x7fff98e02fff libCVMSPluginSupport.dylib (12.1) <D81B3D8D-B83F-3918-BD4B-6C794A30AF9F> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib 0x7fff98e03000 - 0x7fff98e21ff7 libsystem_kernel.dylib (3248.60.10) <C1A6A0B9-1869-36AB-B4A2-D862EB09A4BE> /usr/lib/system/libsystem_kernel.dylib 0x7fff997cc000 - 0x7fff997cdfff liblangid.dylib (122) <9CC4F0D1-5C51-3B69-BC8F-EE3A51FD0822> /usr/lib/liblangid.dylib 0x7fff99ab0000 - 0x7fff99acbff7 libCRFSuite.dylib (34) <078B4CD8-6A8C-3067-B2BA-0C2A0BAB8AC3> /usr/lib/libCRFSuite.dylib
External Modification Summary: Calls made by other processes targeting this process: task_for_pid: 0 thread_create: 0 thread_set_state: 0 Calls made by this process: task_for_pid: 0 thread_create: 0 thread_set_state: 0 Calls made by all processes on this machine: task_for_pid: 69455 thread_create: 0 thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=209.7M resident=0K(0%) swapped_out_or_unallocated=209.7M(100%)
Writable regions: Total=38.4M written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=38.4M(100%)
VIRTUAL REGION REGION TYPE SIZE COUNT (non-coalesced) =========== ======= ======= Kernel Alloc Once 4K 2 MALLOC 28.2M 11 MALLOC guard page 16K 4 Process Corpse Info 2048K 2 STACK GUARD 56.0M 2 Stack 8192K 2 VM_ALLOCATE 4K 2 __DATA 16.4M 175 __IMAGE 528K 2 __LINKEDIT 91.4M 4 __TEXT 118.4M 179 __UNICODE 552K 2 shared memory 8K 3 =========== ======= ======= TOTAL 321.4M 377
- Contributor
- October 25, 2016
Has anyone gotten anywhere with this? We have seen this 2 times in my environment right now and struggle to fix it.
- Author
- Contributor
- October 25, 2016
Fortunately I haven't seen it anymore. Unfortunately that means I haven't been able to troubleshoot it and therefore can't offer any advice.
- New Contributor
- October 27, 2016
@chisox1 No fix that I'm aware. Had two recently as well, re-image is the only thing that I've been able to do.
- Contributor
- October 27, 2016
Due to soem crappy policies around here... I can't re-image machines. I opened up a ticket with Apple but the BP is getting impatient. Hopefully Apple has a miracle fix soon :)
- Contributor
- October 31, 2016
I'm seeing this same issue on a MacBook Pro w/ 10.11.6 today for the first time. Other users are not affected, even new logins. However deleting and re-adding the same user (even though I have moved the old data aside) did not resolve the problem. The "fresh" user account still had the same crashing issues. It nearly every crash seems to indicate a sandboxing issue, but I'm not sure what else to try.
- New Contributor
- November 11, 2016
Still haven't found a fix for this. The only thing I can add is that so far I haven't been able to reproduce this issue on macOS Sierra
- Author
- Contributor
- November 14, 2016
@JamieMacJ : Have you been able to reproduce it on any other OS? I thought everyone had just seen it randomly and couldn't make it occur. If you've figured out some set of criteria under which the issue occurs, please share, as that would certainly help to determine root cause.
Eric
- New Contributor
- November 14, 2016
@etippett I've seen this error on 10.11.x , and for me it seems to be when I have the Forescout SecureConnector installed (network security software). Once I install it, and after rebooting the Mac a few times and/or unplugging/replugging the network cable a few times I can sometimes get the problem to appear. I don't have a specific set of steps to be able to reproduce the issue 100% of the time unfortunately.
- Author
- Contributor
- January 10, 2017
I'm seeing this again today. Did anyone ever figure out a solution? @chisox1 Did Apple provide any input from the case you had open with them?
Thanks,
Eric
- Contributor
- January 10, 2017
Sadly not. We ended up replacing the users machine and reformatting the problem machine for a new user who is having no issues now. Looking through emails, the last thing they said was to reformat and reinstall the OS ha.
- Author
- Contributor
- January 10, 2017
So I finally had some success! The machine that started acting up this morning is now behaving normally due to either one of two things that I did (poor troubleshooting technique on my part for making two changes without testing in between): 1) repairing disk permissions or 2) deleting the contents of /var/folders/. My money is on the latter, as I did see some sandbox-related stuff in there, whereas the disk permission changes were minimal and seemed inconsequential. I know I've seen other weird stuff caused by bad data being cached in /var/folders/ (a good write-up on its function and purpose can be found here, so I don't know why I didn't think to try this until now. After issuing rm -Rf /var/folders/* and rebooting I no longer receive the sandbox error and all apps seem to launch without issue. Hopefully someone else has a system exhibiting this behavior sometime soon and can verify this as a solution.
Eric
- New Contributor
- January 17, 2017
I have been dealing with this same exact problem with one specific user for the past couple of weeks. Everything will work fine for a few days and then the errors will return. I have tried cleaning with Onyx, sudo rm -Rf Library/Containers/*, wiping/re-imaging and even giving the user a completely different laptop. After a few days, the issue comes right back.
Eric, I will go ahead and give your suggestion a try with the /var/folders and report back soon. Glad to know others are having this issue, I was going crazy here. Here is hoping.
-David
- New Contributor
- January 17, 2017
Deleting the /var folder did work! Thanks, Eric.
However, I am afraid that this may be more of a temporary fix seeing as how the issue seems to recreate itself. I just skimmed over the article Eric posted, but does anyone happen to know how the data in /var/folders gets created? Could this be something getting pulled down from an AD account each time/ will the data repopulate?
Thanks for all the help.
Scanning file for viruses.
Sorry, we're still checking this file's contents to make sure it's safe to download. Please try again in a few minutes.
OKThis file cannot be downloaded
Sorry, our virus scanner detected that this file isn't safe to download.
OK
