Profile Installation Failed
  • August 19, 2013
  • 9 replies
  • 77 views
I have looked thru the boards but have not found a resolution for ; Profile Installation Failed - The server certificate for "myserver/enroll/SCEPProfile? invitation=xxxx" is invalid.
I made sure that my certificate is the local jss, the date and time are correct and I have tried different ways to put the server address in the jss http dialog box as suggested.
This is a clean install and I am starting over. The old server was setup bu someone else and was just wrong.
Any thoughts?
Thanks
Shaun
  • September 27, 2013
I have the same problem. When trying to setup the JAMF for iOS 7, I had to reinstall the OS X from a clean and re-formatted RAID1. I am now running 10.8.5 with MySQL 5.5, and Java 7 with Casper 8.72 and my backups form the older 8.71. Everything looks like its there but none of my iPads are "checking in" after the upgrade and I can not add any iPad's into the server ether through Apple Config with an iOS 7 config profile, or Over The Air enrollment.
O.K. I just tried this from a tweet and it works so far. My MDM has picked up nine iPads in two min. and I was able to enroll my iPads into Casper. Here are the steps I used.
Resolution
If your web server certificate is self-signed, there are two ways to resolve the issue:
Replace the web server certificate in the JSS with the certificate from the JSS's built-in CA. Install a public certificate from a third-party CA.
If the root CA certificate is not being installed on the device during enrollment, ensure that this option is selected in the JSS.
To replace the web server certificate in the JSS with the certificate from the JSS's built-in CA:
Log in to the JSS. Click the Settings tab. Click the General Settings link. Click the Server Configuration tab. Click the Replace with certificate from the JSS's built-in CA link, and then click Save. Restart Tomcat. See "Starting and Stopping Tomcat" for instructions.
  • May 14, 2014
This probably seems like a simple solution, but also check that the date and time is correct on the iPad that you are trying to register. The student device I was working with was 1 hour off and this was causing the problem.
  • November 2, 2016
This is a fairly old post, but I wanted to thank @andy.cauble for the common-sense reminder - I had this problem and it was because the date was way off. Like, 1970.
  • November 27, 2017
I know this is an old post, but I wanted to know if @stoomey74 ever found a solution? I too had to switch onto a new server. I had jss running on mac os and the hard drive was failing. I threw the jss onto a windows 2012 vm. I was able to successfully restore the backup. I am now however having issues getting my ipads enrolled. I am receiving the same error. The time on the server is correct and we did not have this problem in our network previously.
Check Time & Date and make sure it is set for you current time zone
  • October 16, 2018
When user Enroll the MacBook. We are facing this issue.Please help me.
  • October 16, 2018
No text available
  • September 25, 2019
I'm getting a profile installation error from my A1822 iPad when trying to enrolling into our Jamf Pro account.
"The SCEP server returned an invalid response."
Anyone seen this error and have a fix for it? Please advise.
  • October 9, 2019
Hi @ravijvp17 I'm facing the same issue. Did you find out the solution, please ?
Best
