Disable icloud 1st boot
  • October 13, 2011
  • 16 replies
  • 84 views
Forum|alt.badge.img+21
Use mxc and disallow access to the prefpane its there for a reason, so admins can administer! Best not move it because you don't know what you may screw up
  • October 14, 2011
the problem with that is then any extras that you want to have in the
system preferences have to be explicitly allowed which gets to be such a
nightmare.
-- Todd Ness
Technology Consultant/Non-Windows Services
Americas Regional Delivery Engineering
HP Enterprise Services
  • October 14, 2011
Oh yes, I've had to do that a few times in the past, but once done, that's it and the users aren't admin to install software so now worries.
  • October 17, 2011
All-
Got the iCloud disable working through MCX. See attached screenshots
j
Jared F. Nichols
MIT Lincoln Laboratory
244 Wood Street
781.981.5436
![external image link](attachments/706f00225cda4d06ac48cfd34aa54e8c)
![external image link](attachments/54684e8ae0004f8b8b9136a401aaa043)
  • October 17, 2011
Hmm...Wonder if it has anything to do with the setting not liking User Level Enforced....
Did you try this with the Trackpad one as well? Or are you not suppressing that?
![external image link](attachments/a0af69d5bb234154ab8b5bac83bd701d)
![external image link](attachments/02fc7982c80f405ca0e6479068cbc847)
  • October 17, 2011
I wasn't going to suppress that one as it's a significant UI change I'd like users to be aware of.
j
Jared F. Nichols
244 Wood Street
781.981.5436
  • October 17, 2011
Yep. Worked for the Gesture Movie as well:
Call me a non-conformist if you will, but 95% of the users we have are all as old skool as possible and would change the scrolling direction in a heartbeat (already asked a few). So for those of you looking to deliver the true "natural" scrolling...this worked for me.
Thanks for the help J.
![external image link](attachments/877a5fc684cb4546bb3bc06796212829)
![external image link](attachments/bcedf32cfcc34b5c9a0be90df9fdc6bd)
Forum|alt.badge.img+20
  • October 17, 2011
Very nice I like!
  • October 17, 2011
Having issues with this and the Trackpad "how to scroll" stuff. Right now I've got 2 prefs set to manage both of these but still get this for new users. Currently I've got 2 custom prefs setup: - com.Apple.SetupAssistant - DidSeeCloudSetup - Boolean - True - GestureMovieSeen - String - I've tried "none" and "Trackpad" still prompts
Both are set to User Level Enforced and scoped to the correct System.
Any better way to prevent these from happening?
Thanks,
Noah
  • October 17, 2011
I just have the did see cloud setup in the user template and it does not
prompt anymore for new accounts that get created.
I have not tried to disable the unnatural scrolling video since its so
unnatural that it might be helpful.
-- Todd Ness
  • October 17, 2011
I'm also seeing the iCloud one not work.
Jared F. Nichols
244 Wood Street
781.981.5436
  • October 17, 2011
Yeah...through MCX I'm going to help the users by setting scrolling to what it has been since the scroll wheel was invented. ;-) Therefore, the "helper" is more of an annoyance.
  • October 17, 2011
I just captured the plist and deployed filling all user templates and that resolved it. Still not sure why MCX wouldn't accept it.
  • October 18, 2011
Is it possible to disable the iCloud preference pane via MCX? I have the MCX
for the initial prompt on first boot, but I want to disable it completely.
Thanks,
Kristen Dietiker
Client Services Manager
UW Department of Surgery
Forum|alt.badge.img+15
  • October 18, 2011
Kristen -
It's on the user level in com.apple.setupassistant.plist ; it's not a preference pane at all, just a regular ol' flat XML plist. You can suppress the iCloud thing on 10.7.2 with it as well. There are a number of ways to conquer this particular beast. Ask if you would like more specific direction.
Michael Crispin
Duke University
  • October 18, 2011
Apologies - I should have read more carefully - you are not trying to suppress the iCloud from first user startup, you are trying to kill the entire iCloud pane.
Have you tried putting no access restrictive permissions on System/Library/CoreServices/PreferencePanes/iCloud.prefPane ?
There are of course a number of other methods that may more or less lead to systems instability, but starting from here I should think would be a good first step.
The dependancies on iCloud are all over the place and I would be careful here as this is something of a unknown venture. My advice is to think long and hard about your security environment and make sure you are not over thinking things.
Michael Crispin
Duke University
  • October 18, 2011
Michael, thanks. I didn't realize that would effectively remove the pane
from the system preferences, which is what I wanted to do.
Kristen Dietiker
