We're transitioning our client computers from one JSS to another. As part of this, we have to remove the current MDM profile before running the QuickAdd package to install the new one. We're doing so with the command profiles -R -p <uuid>. This is successfully getting rid of the MDM profile, as well as all configuration profiles that were installed by the JSS. However, the VPN network service that was created by one of the config profiles still exists. The '-' button to remove it in System Preferences is greyed out and trying to run networksetup -removenetworkservice <networkservicename> gives the following error:
You cannot remove CCAD VPN 1 because there aren't any other network services on IPv4.
** Error: The parameters were not valid.
Any ideas?
Thanks,
Eric
